Android 6.0 Tablet and TV (release candidate, maintained)
#81
[Image: 4d8ee416a9.png]
Still doesn't work Sad Can you please post this uEnv corrected? Maybe I'm doing something wrong.
EDIT: Now I'm burning again the image. A good txt editor? Maybe the error is to use the default of Windows?
#82
Below is my uEnv.txt. Note the bold section.
console=ttyS0,115200n8
selinux=permissive
enforcing=0
optargs=no_console_suspend
kernel_filename=kernel
initrd_filename=ramdisk.img
hardware=sun50iw1p1
# To use android recovery, uncomment:
# initrd_filename=ramdisk-recovery.img
# To enable LCD, uncomment:
# pine64_lcd=on
# Configure contiguous memory allocation
# This maybe required to be enlarged for 4K displays
cma=384M
# To change HDMI display mode, uncomment:
# disp_mode=480i
# disp_mode=576i
# disp_mode=480p
# disp_mode=576p
# disp_mode=720p50
# disp_mode=720p60
# disp_mode=1080i50
# disp_mode=1080i60
# disp_mode=1080p24
# disp_mode=1080p50
 disp_mode=1080p60
# disp_mode=2160p30
# disp_mode=2160p25
# disp_mode=2160p24
# To enable DVI compatibilty, uncomment:
# disp_dvi_compat=on
# To enable CSI camera, uncomment:
# camera_type=s5k4ec
# camera_type=ov5640
# Configure ethernet speed
eth0_speed=auto
# eth0_speed=1000
# eth0_speed=100
# eth0_speed=10
ETA:
Your's appears correct, I do not know why your's is doing what its doing. I had the same problem as you before i realized the space was missing. I added the space and it worked just fine.
ETA 2:
Im using TextEdit on OSx, never used windows for this.
#83
Tried, but nothing Sad I don't think that the board is damaged, with Android 5.1.1 I don't have any problems.
#84
You may have to wait for AYUFAN to chime in. Sorry I couldn't help.
#85
Could you attach your .txt so I can copy-paste it directly? Maybe there are problems when we wrote text here and we try to copy-paste
#86
Is your TV capable of 1080p?
#87
(12-17-2016, 03:04 PM)Bluphire Wrote: Is your TV capable of 1080p?
Yes. When I use Android 5.1.1, it appears "1920x1080p60" on the screen, same with my PS3.
#88
I'm out of ideas. Sorry man.
#89
(12-17-2016, 03:19 PM)Bluphire Wrote: I'm out of ideas. Sorry man.
Don't worry. Thanks for the help ^_^
#90
Nittola: I think that you have some problem with your install, as I did install downloaded image and it works correctly. How do you see that it is not working?
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
  Need help compiling android for pine a64 + YeeticusMaximus22 1 1,769 12-13-2025, 09:23 AM
Shocked Remote for Android? liodra 18 47,669 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 30,382 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,006 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 13,365 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 9,957 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,348 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 392,146 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,080 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 156,019 02-10-2019, 07:44 PM
Last Post: mmmarcus
