Android 6.0 Tablet and TV (release candidate, maintained)
#31
yantoz: which version do you use? the last time I did check the ATV were working correctly. I saw this issue before, I know what is causing that, and I thought that it is released with the latest build. Will check that.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
#32
(12-01-2016, 03:46 PM)ayufan Wrote: yantoz: which version do you use? the last time I did check the ATV were working correctly. I saw this issue before, I know what is causing that, and I thought that it is released with the latest build. Will check that.
The latest one: v0.3.0-r13
#33
I have the same issue with Android Remote and the same version.
#34
I tested it, it's broken. I'll push a fix for it.
Fix is there, but is seems that it doesn't work Smile
We miss `libatv_uinputbridge.so` for lib32.
Releases:
Buy me a Beer
#35
(12-01-2016, 04:32 PM)ayufan Wrote: I tested it, it's broken. I'll push a fix for it.
Yes, as the log says. Looking forward to your next release. Thanks for the great build anyway.
#36
I have a Kodi media center (raspberry pi) connected to my Samsung TV and use TV remote via CEC. Once the pine is started with tablet version the CEC seems to be disturbed and is not working anymore. Is CEC enabled in tablet version? If yes, is there a way to disable?
#37
Yes, it's enabled. No there's currently no way to remove it.
Releases:
Buy me a Beer
#38
(11-30-2016, 11:27 AM)tommypine Wrote: I can't access Videos located on a USB-Stick with Kodi. The Stick dosen't show up. With ES File Explorer i can access them.
If i click on them in ES then i can play them in Kodi, but i can't add it as video source. Any help?
Thanx for no answers.......................[Image: dodgy.png]
#39
tommypine: hmm, not sure what to answer, this doesn't seem to be problem with system, only with specific application as you say that you can access it with ES File Explorer. I would advise to ask creators of the application about it.
Releases:
Buy me a Beer
#40
(12-02-2016, 08:19 AM)ayufan Wrote: tommypine: hmm, not sure what to answer, this doesn't seem to be problem with system, only with specific application as you say that you can access it with ES File Explorer. I would advise to ask creators of the application about it.
You're right, seems to be a Kodi thing  [Image: rolleyes.png]
  Need help compiling android for pine a64 + YeeticusMaximus22 1 1,540 12-13-2025, 09:23 AM
Shocked Remote for Android? liodra 18 46,922 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 29,958 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 11,795 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 13,150 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 9,773 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,205 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 389,039 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 6,939 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 154,297 02-10-2019, 07:44 PM
Last Post: mmmarcus
