(ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release
(10-12-2016, 05:59 PM)neil85ae86 Wrote: I am not having any luck getting this (pine64-image-debianmate-310102bsp-2.img) running on my 512mb board (pine power supply, Costco 32gb Sandisk Ultra). At some point I get really odd behavior like recursive windows popping open that can't be stopped, write errors on boot etc. and while it was running I wasn't able to get the wifi working. Each reboot it seems to deteriorate to the point where it won't boot anymore, I get about 3 reboots then I have to reimage. I've tried USB writer and Image Writer, Win32 Disk Imager. Any other suggestions? I bought two of these cards at the same time and the other one is working fine in my 2GB pine so I don't think it's the card (2 pack from Costco).
May also be powering issues, they also cause some weird behaviour....
Do you have sufficient power resp. even using EULER bus?
Gesendet von meinem XT1032 mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
Got everything installed, booted a couple of times, now it will not accept the debian password??
(10-15-2016, 09:46 AM)clarkss12 Wrote: Got everything installed, booted a couple of times, now it will not accept the debian password??
This is probably not a password problem, per se; rather, it is more probably a memory issue-- 512 is simply not enough.
???????  I have the 2gig version..  I used gparted and expanded my 64gig microSD card to the full amount....
my bad... sorry... I thought your version was 512... never mind.
I am at a loss to understand why the signon would not allow the debian password; other than corruption of the SD card....
Update, really strange, left board at the log in screen for a few hours and changed TV inputs so I could use another Android box. Came back to this board and was able to sign in. Now have to figure out how to get settings to 1080p instead of 720p, because the top and bottom bars are off screen.
(10-15-2016, 03:31 PM)clarkss12 Wrote: Update, really strange, left board at the log in screen for a few hours and changed TV inputs so I could use another Android box.  Came back to this board and was able to sign in.  Now have to figure out how to get settings to 1080p instead of 720p, because the top and bottom bars are off screen.
Glad you got your signon to work.
(10-05-2016, 04:18 AM)MarkHaysHarris777 Wrote:
(10-05-2016, 03:08 AM)Kaupy Wrote: I have the 512mb version of the Pine64. I downloaded the Debian Jessie Mate software which wrote to the microsd okay and it boots up okay. The trouble is, it won't except debian as the password or user. Do have the wrong version?
Only you know that.
... obviously one thing to check is that your keyboard is in lower case; userids and passwords are case sensitive.
You may have downloaded the wrong image... try ubuntu | ubuntu
Solved! Corrupt image. downloaded new image and all good
(10-13-2016, 09:27 AM)androsch Wrote: May also be powering issues, they also cause some weird behaviour....
Thx for the input. I did purchase it with the power supply so I wouldn't have to waste any time trying to eliminate that problem. I do have to admit power was my gut feel. I do have some name brand 2-3 amp tablet chargers here that I could possibly try....
Good day.
Is it possible to upgrade from jessie to streth line? I'v tried, but unsuccessful. I disabled jessie repos, enabled stretch repo, made -upgrade and then -dist-upgrade. But cannot to start Xorg due to "ABI version mistmach". (i want to install Teamviewer from Raspbian, it needs more last versions of libraries. And more - trere is no Double Commander and normal mplayer in jessie repo) (i am new in linux, just playing)
  Debian installer on Pine A64+ but no hdmi mrwick 1 8,951 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 20,196 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 5,418 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 16,612 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 164,510 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 8,294 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 7,645 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 10,850 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 20,833 03-29-2019, 02:00 AM
Last Post: desai_amogh
  how to set kernel parameter 'fsck.mode=force' marcelser 6 20,827 05-09-2018, 09:07 PM
Last Post: pfeerick
