The 6 most common reasons why Pine64 won't boot
#81
(07-14-2016, 10:00 AM)DonFL Wrote: Loading a linux image and seeing if you can ssh into the board (suggestion 5, above) would tell you a lot, especially considering display issues are a common start-up issue that users battle. That would definitely be the next step I'd take.
Yeah that's definitely my next attempt. I've got my Pine64 and a Raspberry Pi 3 to mess with over the next few days. Hopefully good news by the weekend Smile
#82
Update: It's working! Appreciate the suggestions everyone. My fix was the display issue, I did a reset on the board to allow it to boot and it magically fixed the HDMI output. Next mission, the touchscreen setup.
#83
Hi everyone,
I am having similar issues as stated above... has this been resolved for the touchscreen/LCD?
I have managed to successfully burn and boot into an android DD image and a Remix OS image using an HDMI out. However, I have not managed to pass the boot screen on the LCD using an android DD LCD panel image. The image does show on the screen but I never pass the boot screen.
I have tried two cards (16Gb and 32Gb) in the hopes a different image or a different card would fix the issue. This was not the case. I burned the Android .img using Mac OS X El Captain with the following dd command:
sudo dd bs=1m if=path_of_your_image.img of=/dev/rdiskn
Where "path" is replaced by the image path and "n" by the unmounted disk number. Again, this worked for the Remix OS and Android image no problem. The issue occurred when I tried loading and booting into the touchscreen image.
Info: I have a Pine64+ 2Gb model with only the LCD, wifi/bluetooth dongle and the power connected to the board.
Any help would really help. Not sure what else I could try? Thanks!
______
Ps: Remix OS on the 2GB model is very very slow... Android through HDMI is rock solid.
#84
I had a few more issues that were not covered in this forum, so I wrote about them on my blog.
http://techscout.online/2016/07/29/pine6...eshooting/
#85
(07-29-2016, 10:07 AM)harveys300@ Wrote: I had a few more issues that were not covered in this forum, so I wrote about them on my blog.
Thanks for the blog.
#86
After many many attempts with my Pine Plus 2Gb LCD. Something is working albeit very very slow. I tried on 2 different microSD cards (64Gb and 8Gb) the two versions of Android 5.1.1. Normally it crashes after the 2nd boot-up screen showing intermittent narrow white vertical lines. I ruled out the power supply issue, had that too, and am using a decent 2A USB plug now. It's working but extremely slow. Should I change for another microSD? Using Kingston 8Gb now.
#87
We recommend the Samsung evo plus cards... much faster, more reliable.
#88
(10-02-2016, 07:35 AM)MarkHaysHarris777 Wrote: We recommend the Samsung evo plus cards... much faster, more reliable.
Thanks Mark. I'll order those and see how that will work out for me. A different simple question. If I closed the LCD ABS enclosure there is no decent way to get in right? With those clips.
#89
The 'hack' we are recommending for that is to take a very small dremel bit and drill a paper-clip sized hole at the location of each tab.  Then to open the case simply push a paper clip into the hole(s) to pop the tab loose.  Some folks tried melting or burning a hole ( not recommended ).  The dremel tool is your friend... if you don't have one try to borrow one, but a dremel is kinda like a soldering iron... every shop should have one.
#90
I do own a dremel and this is not a bad suggestion at all. 6 of those tabs is then still not easy I believe... :-)
  Star64: All listed distros don't boot tantamount 0 1,154 05-08-2026, 08:56 AM
Last Post: tantamount
  Having trouble reading MPU6050 sensor via I²C on Pine64 Jaxon 3 10,508 10-21-2025, 10:13 AM
Sad PINETAB-V doesn't boot. FEC 1 3,962 08-23-2025, 02:58 PM
Last Post: Woazboat
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 3 6,917 12-10-2024, 07:23 PM
Last Post: Dendrocalamus64
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 3,573 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 4,049 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 4,957 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 3,540 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,802 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 7,193 06-17-2021, 05:35 AM
Last Post: kqlnut
