(ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release
Let's try to keep it clean, and friendly. Everyone working on this project is doing there utmost to achieve quality and integrity; and many of them are volunteering their time and energies to same.
Please be respectful, and help be a part of the solution, if possible.
marcushh777
Hi, I hope someone can help me out.
I am trying to get a Prolific 2303 usb to serial adapter to work with the latest debian Base release. It works on a RPI but on the Pine you can see the plugged in adapter but it does not get linked to a tty-usb port. Other usb to serial adapters of a different make do get attached to a tty-usb port.
Is the driver included in the build?
Regards,
Jelle
The driver for the PL2303 does exist, and has been tested , but is not included yet in the standard build. This should be happening soon, if it has not happened already.
I noticed that you cross-posted. You need only ask your question once; regardless which sub-forum you post in, we will see your question. Please do not post the same question twice. Thanks.
Yes, sorry about that. Tappatalk mishap.
Just updated to the new release and it works like a charm!
Regards,
Jelle
Anyone know a way to wake up the console (HDMI) when it won't wake up with keyboard or mouse activity?
I know the Pine is still up - because I've got an active SSH connect to it...
It goes to sleep on the Motorola Lapdock - and won't wake up - not from the keyboard / mouse on the lapdock, or external keyboard / mouse connected via USB...
Not to worry - I had to reboot it - and I've put it to "never" for everything for the display in Power Settings...
-- edit --
Also - would anyone know why this build of Debian barfs when I try to install synergy?  :
x@pollux:~$ sudo apt-get install synergy quicksynergy
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
quicksynergy:armhf : Depends: libatk1.0-0:armhf (>= 1.12.4) but it is not going to be installed
                     Depends: libgdk-pixbuf2.0-0:armhf (>= 2.22.0) but it is not going to be installed
                     Depends: libglib2.0-0:armhf (>= 2.16.0) but it is not going to be installed
                     Depends: libgtk2.0-0:armhf (>= 2.10.0) but it is not going to be installed
                     Depends: libpango1.0-0:armhf (>= 1.14.0) but it is not going to be installed
                     Depends: synergy:armhf (>= 1.3.1) but it is not going to be installed
synergy : Depends: libcrypto++9 but it is not going to be installed
          Depends: libqt4-network (>= 4:4.5.3) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
As you can probably see from above - it's somehow trying to install armhf packages... Is there a way I can force it to go for arm64 ?  Normally I change my /etc/apt/sources.list to point at my ISP's debian archive/mirror - but in this case I have not touched the one shipped with this most recent build of XFCE Debian from Longsleep :
deb http://ftp.us.debian.org/debian jessie main contrib non-free
deb-src http://ftp.us.debian.org/debian jessie main contrib non-free
deb http://security.debian.org/ jessie/updates main contrib non-free
deb-src http://security.debian.org/ jessie/updates main contrib non-free
deb http://ftp.us.debian.org/debian jessie-updates main contrib non-free
deb-src http://ftp.us.debian.org/debian jessie-updates main contrib non-free
deb http://httpredir.debian.org/debian jessie-backports main contrib non-free
More broken dependancies... couldn't even install mysql-server... (although postgresql installs no problem)
(07-19-2016, 08:19 AM)ngmacha Wrote:
(07-01-2016, 08:16 PM)lenny.raposo-pine64.pro Wrote: Has anyone run into any issues with resizing the rootfs with the script?
Wanna find out if this is just an isolated incident or something more.
Let me know
Yes, and I found the error: missing a blank line after $start and before 'w' - I've edited the script and everything runs OK!
Thank you for this! I've been fighting it for hours!
You guys are GREAT and I appreciate so much all the work you are doing!
(09-05-2016, 12:13 AM)UnixOutlaw Wrote: As you can probably see from above - it's somehow trying to install armhf packages... Is there a way I can force it to go for arm64 ?  Normally I change my /etc/apt/sources.list to point at my ISP's debian archive/mirror - but in this case I have not touched the one shipped with this most recent build of XFCE Debian from Longsleep :
The package isn't available for arm64 on Jessie, and since the images enable armhf as a foreign architecture, apt-get tries to use that instead. You can try to figure out why the dependencies can't be installed using the armhf versions, or rebuild the package!
If I'm reading the dependency list errors right libcrypto++9 is the blocker, as it is preventing synergy from installing, and quicksynergy depends on synergy, so that naturally fails also. Didn't I see somewhere on the forum that the pine64 could still run armhf stuff? Maybe on ubuntu? Or am I not remembering that properly? I thought apt just needed to be told to also look for a second architecture as long as thee kernel had the right flags set to enable support?
I don't know why libcrypto++9 won't install? https://packages.debian.org/jessie/arm64...9/download
Sent from my HTC 10 using Tapatalk
  Debian installer on Pine A64+ but no hdmi mrwick 1 9,251 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 20,838 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 5,681 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 17,172 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 167,400 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 8,566 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 7,923 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 11,297 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 21,481 03-29-2019, 02:00 AM
Last Post: desai_amogh
  how to set kernel parameter 'fsck.mode=force' marcelser 6 21,485 05-09-2018, 09:07 PM
Last Post: pfeerick
Users browsing this thread: 8 Guest(s)
