No IMG file after extracting Android dd
I've extracted the un-rooted DD image for 8GB SD card, and there is no IMG file to burn to the SD card. What am I doing wrong?!?
Thanks (complete noob)
(08-04-2016, 04:24 PM)tomwjr Wrote: I've extracted the un-rooted DD image for 8GB SD card, and there is no IMG file to burn to the SD card. What am I doing wrong?!?
Hmmm. What are you left with then, if not an image file?
    Here is a screenshot of what is extracted.
How embarrassing, and how funny; really.
Where did you pull the image from ? We'll fix it...
(08-04-2016, 11:59 PM)MarkHaysHarris777 Wrote: MarkHaysHarris777How embarrassing, and how funny; really.
Android 5.1.1 Image (HDMI Video Output) Release 20160711
It was the 8GB non-rooted version.
DD images:
DD images:
Thank you, we'll look into it.  something is goofy because what you're looking at is more or less normal, but you should not be able to mount it and see it in windoze;  how did you produce your pic?
Thanks.
DD images:
Thanks.
That is a screenshot of my windows explorer after extracting the file with 7-Zip. I've downloaded and extracted it a couple of times, and that's what I get each time. No IMG file, just the folders and files you see in the screenshot.
DD images:
Thanks.
Thank you, definitely we will look into this !
DD images:
Thanks.
Thank you, I appreciate it. Just as an FYI, I just downloaded and extracted the previous 8GB Version and it extracted to an IMG file just fine.
(08-05-2016, 07:38 AM)tomwjr Wrote: Android 5.1.1 Image (HDMI Video Output) Release 20160711
DD images:
Thanks.
I have the same problem with Android ver 6.0 Marshmallow , I've downloaded it twice ,same results , unzips what looks like files in an android directory . Just guessing ,I'm more of a Windows person. Wink
Question Do I need a touchscreen to run Android? chrbar 3 8,599 08-08-2018, 10:55 PM
Last Post: chrbar
  ethernet lan speed problem android fulltone 0 4,035 04-23-2018, 01:47 AM
Last Post: fulltone
  No sound on Android 6 or 7.1 reeno 0 4,310 07-29-2017, 06:31 PM
Last Post: reeno
  Android pretty slow Passiday 2 7,954 10-08-2016, 03:46 AM
Last Post: Passiday
  Can't make the Android image boot Passiday 3 8,925 10-07-2016, 09:34 AM
Last Post: Passiday
  LCD screen with android, runs fine, screen does not turn back on..? GhostlyAspens 2 6,803 09-01-2016, 12:24 AM
Last Post: GhostlyAspens
  Can't get past the "Allwinner/Android" screen d34532 2 7,599 07-10-2016, 08:21 PM
Last Post: d34532
Thumbs Down Issues with Android mliebski 0 3,281 07-01-2016, 11:14 AM
Last Post: mliebski
  Android Touchscreen/HDMI Severian 2 7,911 06-18-2016, 03:28 PM
Last Post: Severian
  Android: Works on monitor but not on HDTV wickemt 2 7,632 06-13-2016, 09:54 AM
Last Post: wickemt
