HDMI and LCD
Dear all,
Please let me know which Os can Pine64 run with both of LCD touch screen and HDMI output for monitor?
Regards,
Huu Hien
hi my homies on the irc.pine64.xyz site tell me that non of the gnu+linux distros support the LCD screen yet.
Android and Remix support the LCD touch screen, as well they boot up to hdmi (depending on your monitor). I do not have my LCD yet... so I cannot test, but I have booted Android into hdmi monitor.
marcus
(07-05-2016, 06:48 PM)MarkHaysHarris777 Wrote: hi my homies on the irc.pine64.xyz site tell me that non of the gnu+linux distros support the LCD screen yet.
marcus
I didn't know that there was a build of RemixOS that supported the LCD touchscreen yet, when did this happen?
LCD only supports android for now. Remix will supposedly be supported in the future. Linux -- it depends on how much the linux community cares, it may happen Wink
It should be noted that Android supports both HDMI and LCD, but not simultaneously. Only HDMI or only LCD.
Matt
While the hardware is perfectly capable of dual headed output, you need the right kernel driver and configuration to achieve that. Once I get my LCD I'll try to get it up an running with Linux, maybe look into the dual head issue...
(07-06-2016, 05:18 PM)Bluphire Wrote: It should be noted that Android supports both HDMI and LCD, but not simultaneously. Only HDMI or only LCD.
Matt
Actually the latest build of Android with LCD support ( http://wiki.pine64.org/index.php/Pine_A6...e_20160603 ) supports using both HDMI and LCD at the same time.  It is a cloned image and not sure if able to set up to use as a multiview or continual screen.  I know this is working as I use it to play pokemon red on a hdtv through HDMI cables and it also shows on my LCD at the same time.  Kinda overkill but cool none the less.
Matt
Thanks for this info, greatly appreciated.
Yeah, I can use both of HDMI and LCD at the same time (with LCD image), but It can't boot when it is connected to HDMI.
Ya it mirrors the image does not boot while hdmi is connected but works nice
What I have not tested is if the audio works via hdmi
But it woks via 3.5mm jack
Sent from my Xperia V using Tapatalk
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
  Pine HDMI -> DVI monitor Pineapple 4 12,923 09-10-2019, 11:28 AM
Last Post: Pineapple
  First Boot HDMI/USB problem reefer 1 7,437 11-18-2018, 10:32 PM
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 12,790 04-15-2018, 07:37 AM
Last Post: bunkerWHz
  HDMI "Format not supported" sam452 3 10,411 06-11-2017, 10:38 AM
Last Post: Beta_Ravener
  RESOLVED - LCD screen not working, HDMI does asuras 10 24,635 04-02-2017, 08:12 AM
Last Post: Luke
  HDMI-VGA adapter. Blank screen. trumad 10 27,879 03-05-2017, 03:17 AM
Last Post: pfeerick
  no sound over HDMI mbjpine64 2 7,076 10-09-2016, 01:45 PM
Last Post: dicenicheserr
Question No Audio other than HDMI jwouellette 8 16,080 08-03-2016, 03:08 PM
Last Post: jwouellette
  HDMI Video Resolution patmolloy 11 31,859 07-27-2016, 10:37 PM
  No HDMI output (don't think the boards are dead) thegooddoctor 15 39,250 07-17-2016, 12:00 PM
Last Post: thegooddoctor
