PINETAB-V doesn't boot.
Sad
I recently got my PINETAB-V. I connected the USB-C power cable and pressed the power button for exactly 2 seconds, as instructed in the manual.
It looked like the OS was about to boot, but the following message has been repeating for over 4 hours:
`[21966.202233] [WARNING][BB]Skip gain error setting in scan status`
According to the documentation at [https://pine64.org/documentation/PineTab-V/\_full/]
> The 2nd batch of PineTab-V devices ship with a Debian Bookworm image from StarFive.
So I was expecting the OS to be pre-installed — is that not the case?
I just got a pinetab-v as well and had a similar problem where it failed to start the graphical interface when booting from the pre-installed system image from emmc.
I was able to log in from the serial console from my pc using the uart adapter, only the GNOME graphical shell wouldn't start.
The issue turned out to be a corrupted file system. The kernel log was full of ext4 fs errors and running fsck (in read only mode since the file system was still mounted) found plenty of errors as well.
Putting the provided system image https://github.com/starfive-tech/Debian/...b-V-v1.3.0 onto an sd card worked fine and booted into the graphical interface without errors. Once you're running from the sd card and the emmc root partition (`[color=oklab(0.952331 0.000418991 -0.00125992)]/dev/mmcblk0p4[/color]`) is no longer mounted, you can run fsck on it to fix the file system errors (answer yes to all). After doing that, booting from the internal emmc worked properly and it successfully started the graphical interface.
The periodic ` [WARNING][BB]Skip gain error setting in scan status` message seems to be unrelated.
  Star64: All listed distros don't boot tantamount 0 1,027 05-08-2026, 08:56 AM
Last Post: tantamount
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 3 6,749 12-10-2024, 07:23 PM
Last Post: Dendrocalamus64
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 3,483 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 3,995 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 4,876 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 3,485 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  How to boot from SD card on pinebook pro linux123 3 10,352 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 5,653 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 3,779 10-18-2020, 01:41 PM
Last Post: toiny
  SD Card boot - trying out OS Baconomics 1 7,174 06-19-2020, 06:58 AM
