01-20-2022, 12:37 PM
Thanks for the reply, the image link is broken though
NVMe drives not detected
03-04-2022, 01:27 AM
My Patriot P300 turned up and worked (before I decided to reinstall my PBP)
03-05-2022, 04:53 AM
Interesting. I've still had no luck with the taping. I may try things out with the case open but that isn't recommended/decidedly awkward.
I have a similar yet different issue in that my Toshiba XG5 256GB is detected in lspci, but not in lsblk.
According to https://wiki.pine64.org/index.php?title=...SSD_drives the XG6 should work, so I was hoping my XG5 would also. Code: 2024-11-18 05:56:15 root@pinebook-pro:~# lspciEDIT: I'm also annoyed that the NVMe is more difficult to swap than it really needs to be. The screw holding the NVMe to the sub-board should be easily accessible instead of removing the entire sub-board to then remove the NVMe.
12-17-2024, 09:23 PM
Did you see my post immediately below?
skysmotor.co.uk sells the following products online: dc servo motor, geared stepper motor, stepper motor drivers, planetary gearbox and can be purchased online if required.
12-19-2024, 12:46 PM
I also used the Wiki and taped my cable down; The power consumption was a lot so I eventually removed it.
PinePhone, Pinebook Pro & PineTab2 owner.
12-19-2024, 04:33 PM
(12-19-2024, 12:46 PM)dachalife Wrote: I also used the Wiki and taped my cable down; The power consumption was a lot so I eventually removed it. Probably you don't, but do you have any kind of benchmark comparison? I never installed mine because I figured it would use too much power.
:wq
12-24-2024, 12:39 PM
(12-19-2024, 04:33 PM)KC9UDX Wrote:(12-19-2024, 12:46 PM)dachalife Wrote: I also used the Wiki and taped my cable down; The power consumption was a lot so I eventually removed it. It was really noticeable on battery, no benchmarks though. Once I hit 48% battery it was time to shut down. This was with a Samsung, on power/docked it worked fine.
12-24-2024, 08:54 PM
(12-24-2024, 12:39 PM)dachalife Wrote: It was really noticeable on battery, no benchmarks though. Once I hit 48% battery it was time to shut down. This was with a Samsung, on power/docked it worked fine. I have 3 (well 2 are mine and the 3rd I guess I'm responsible for fixing when it Linuxes); and the older two, one mine, have terrible power management. They never get to 100%, never have. They don't actually charge with the display on, the discharge just slows down (a lot). The third, (newest,) has never had these problems: it charges quickly even if the CPUs are overclocked, and will reasonably reach 100%. I'll find out soon if this was battery related: I have to replace all three; they have expanded to the point of breaking the hinges! But I suspect not because that one is the ’new’ main board design (at least was when it was new). So anyway I wonder if that matters. I suppose I could buy an NVMe "drive" to see. Though I most likely cannot afford one at the moment. Alas, I did just buy $90 of accordion parts I didn't really need.
:wq
| NVMe | reukiodo | 0 | 1,672 |
11-18-2024, 09:00 AM Last Post: reukiodo |
| New Working nVME | gilwood | 1 | 2,773 |
11-17-2024, 04:24 AM Last Post: reukiodo |
| NVME problems 2022 / Intel 660p 1TB | Starbug | 1 | 3,902 |
04-04-2023, 12:16 PM Last Post: globaltree |
NVMe adapter, Great addition | dachalife | 2 | 4,017 |
11-28-2022, 12:56 PM Last Post: dachalife |
| NVme intall usage? | tkudog | 2 | 5,043 |
03-04-2022, 01:29 AM Last Post: Tazdevl |
| Anyone selling a spare NVMe adapter in Europe? | tom.tomasz | 1 | 3,495 |
01-03-2022, 07:57 AM Last Post: tom.tomasz |
| NVMe SSD testing methodology | halogen | 1 | 4,488 |
07-22-2021, 05:57 PM Last Post: calinb |
Battery stops charging and NVMe and other media disconnect randomly | Eey0zu6O | 4 | 8,459 |
07-09-2021, 08:45 PM Last Post: moonwalkers |
| nvme drive disappears after about an hour of uptime | codebreaker | 24 | 48,213 |
02-09-2021, 11:32 PM Last Post: dsimic |
| Speakers not detected | PineHead7 | 1 | 4,373 |
01-07-2021, 01:50 AM Last Post: ab1jx |
