How to update/compile Debian 12.5?
I am running Debian 12.5 on my Rock64. I am using the nightly images https://d-i.debian.org/daily-images/arm6...rd-images/ offered here.
The image works great for the most part.
I would really like to fix two things.
1. There is a 5v error related to the DTS file that has what looks like an easy patch to implement.
  rockchip-pinctrl pinctrl: pin gpio0-2 already requested by vcc-host-5v-regulator; cannot claim for vcc-host1-5v-regulator   rockchip-pinctrl pinctrl: pin-2 (vcc-host1-5v-regulator) status -22   rockchip-pinctrl pinctrl: could not request pin 2 (gpio0-2) from group usb20-host-drv  on device rockchip-pinctrl   reg-fixed-voltage vcc-host1-5v-regulator: Error applying setting, reverse things back
Described here: https://patchew.org/linux/20230421213841...@brun.one/
2. I would like to see the boot messages during boot time.
That requires removing the quiet option from the boot.scr file to the best of my understanding. As far as I can tell that requires it to be recompiled too.
Can anyone point me to a guide for doing these changes? I am fairly comfortable at the CLI, but I have never tried to compile like this before.
In order to see all the messages you'd need a serial console. The process is described here: https://forum.pine64.org/showthread.php?tid=5029
Btw I have the same messages on `Debian 6.1.76-1 (2024-02-01) ` on my Rock64.
(02-22-2024, 01:09 PM)Wizardknight Wrote: I would really like to fix two things.
The best way would be to ask the upstream Stable kernel maintainers to apply this patch to 6.1.
If that happens, then the Debian kernel will 'automatically' get it too when it upgrades to a newer 6.1 kernel.
Otherwise you'd have to stop getting kernel upgrades from Debian and/or recompile the kernel to upgrade yourself.
How do you make the Debian installation work, since I have combined the 2 installations as they say in the tutorial and then I have installed it on the SD card and it does not start or at least I do not see an image in the Rock64 output
  Rock64 - not booting after Armbian update helpmerock 7 7,920 01-24-2026, 04:44 PM
Last Post: ff255
  problem with debian emmc boot G4zCDzWb 10 31,263 11-01-2024, 04:32 PM
Last Post: bits
  Debian installation via sd card oaFJSADBKV 0 2,767 10-12-2024, 10:24 AM
Last Post: oaFJSADBKV
  Rock64 Debian 11 (Bullseye) install problem jbize 15 25,566 10-12-2023, 05:14 PM
Last Post: tpaul
  rock64-debian-mrfixit-190531.img.xz : missing /usr/lib/dri/rockchip_dri.so popi 5 10,468 08-12-2021, 04:55 AM
Last Post: igorp
  Debian build from mrfixit2001 Luke 18 45,067 05-17-2021, 02:35 AM
Last Post: Wizzard
  Spinlock Lock after Firmware Update Watcher 4 8,392 02-18-2021, 08:52 PM
Last Post: Rocklobster
  Debian kernel stuck at 4.4.167 Enig123 5 11,065 12-29-2020, 12:57 PM
Last Post: kwinz
  How can I update from Ubuntu 18 to Ubuntu 20? gedas07 3 7,706 10-04-2020, 10:02 PM
Last Post: tomarm
  Debian (Vanilla) on Rock64 and eMMC - how ? as365n4 4 10,103 09-21-2020, 04:33 AM
Last Post: as365n4
