Pinecil v2 power cycles at higher voltages?
Question
Just got a v2, and love it. When I run it off of a 20w USB power supply at 9v (over USB-C) or 12v (with USB-C to DC), it runs fine. However, I have two USB power supplies that it can negotiate 20v with (with the DC cable, natch). One of them is a 100w, so it negotiates 20v/5a, and works fine. The other one is a 65w, so it negotiates 20v/3.25a, and once I hit the + to start it warming up, it blinks just for a second, power cycles, and dumps me back to the main menu.
Seeing as it runs fine negotiating 9v/2a on a 20w channel, and 20w/5a on a 100w channel, I'm not sure why it's choking on 20v/3.25a. This is on the latest stable IronOS firmware, v2.20, with no changes to default settings other than fast scrolling and blinking temp during cooldown. Any ideas?
(03-14-2023, 03:10 PM)clemon79 Wrote: Just got a v2, and love it. When I run it off of a 20w USB power supply at 9v (over USB-C) or 12v (with USB-C to DC), it runs fine. However, I have two USB power supplies that it can negotiate 20v with (with the DC cable, natch). One of them is a 100w, so it negotiates 20v/5a, and works fine. The other one is a 65w, so it negotiates 20v/3.25a, and once I hit the + to start it warming up, it blinks just for a second, power cycles, and dumps me back to the main menu.
Is your another unstable 20V PD charger Baseus brand name? If yes, try latest firmware in Pinecil. If doesnt help, use another PD charger.
I had similar issue, you can check my neighbored topic here.
(10-09-2023, 01:38 AM)Neitron4ik Wrote: Is your another unstable 20V PD charger Baseus brand name? If yes, try latest firmware in Pinecil.
It wasn't a Baseus, but many thanks, a firmware update fixed the issue, and it's working like a champ on 65w chargers now.
pinecil v2 with latest firmware and a ugreen nexode 140W. Goes up to 28.3 Volts and therefore heats up to max 420 degrees in 4 seconds!
  my pinecil v2 is not working jagrav 0 401 04-17-2026, 06:28 AM
Last Post: jagrav
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 2,414 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 555 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 969 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 1,175 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 4,365 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 9,117 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 5,259 05-15-2025, 10:41 AM
Last Post: dreieck
  Pinecil v2 issue autumnharris 0 1,432 05-15-2025, 01:35 AM
Last Post: autumnharris
  Pinecil constantly cutting out WroughtIron 1 3,196 01-16-2025, 02:20 AM
Last Post: D4veC4rter
