Armbian and LibreELEC and AltLinux for Quartz64
ArmbianTV 20230918 kernel current 6.4.16 and edge 6.5.4
new u-boot 2023.10-rc4
Hello! I am interested in building a Quartz64A 8GB based headless NAS (Pine64 NAS case, eMMC module, PCI-e SATA card, 2x HDDs, power supply). I currently have a RockPro64 4GB based NAS in an identical setup which ran perfect for years. Now I'd like an extra NAS.
Is there an image available for the Quartz64 that supports/enables all hardware for such a setup? Do I understand correctly that the official Armbian images (found here) do not work? @balbes150 I see you posting version updates to several OS images. Where can these be found/downloaded? Is a 'normal' Armbian image available? Either way, thanks for all the hard work you seem to be doing Smile
Cheers!
Thomas
PinePhone (BH 2GB + CE 3GB) // RockPro64 4GB (rev. 2.1) - OMV NAS // PineH64 3GB (model B) - off-prem OMV NAS // Pine64-LTS 2GB (rev. 1.2 + Playbox) - Domotics server
(10-02-2023, 12:06 AM)p1x3l3d Wrote: Hello! I am interested in building a Quartz64A 8GB based headless NAS (Pine64 NAS case, eMMC module, PCI-e SATA card, 2x HDDs, power supply). I currently have a RockPro64 4GB based NAS in an identical setup which ran perfect for years. Now I'd like an extra NAS.
Cheers!
Thomas
Maximum hardware support in CURRENT. Although the EDGE version can also work for a headless server. You can test both versions and check which ones better support your specific PCIe hardware.
I don't check the official images at the specified link and don't know if they work or not.
See the first post of this topic, there are all links to images by models.
Libreelec kernel 6.4.16
Armbian kernel current 6.5.5 and edge 6.6-rc4
Altlinux kernel 6.5.5
Libreelec kernel 6.5.5
Armbian kernel current 6.5.9 and edge 6.6.0
Libreelec kernel 6.6.1
Armbian kernel edge 6.6.1
Armbian kernel current 6.5.11 and edge 6.7-rc1
Armbian kernel current 6.6.28 and edge 6.9-rc5
I finally have time to start my blade, let's try it with Armbian.
Thanks for the good work!
  USB on Quartz64 Zero litbulb 2 3,056 11-09-2026, 01:33 PM
Last Post: elizabethtaylor
  DietPi OS for Quartz64 MichaIng 48 65,218 07-22-2026, 01:52 PM
Last Post: MichaIng
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 19,137 03-07-2026, 04:21 PM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 2,734 07-30-2025, 07:19 AM
Last Post: pugzarecute
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 95,025 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 6,233 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 5,023 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 5,982 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 11,793 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 4,394 07-21-2022, 01:08 PM
Last Post: Randomuser
