01-30-2023, 11:36 AM
Hello, I have been using chatty for jabber, but there's this thing that after the phone goes into suspennd mode, the incoming messages cannot be decrypted. Is there a fix for that?
Chatty does not work after suspend mode
Hi, I think the issue you're experiencing is related to the way that your phone handles background processes when it's in sleep mode. When your phone goes into sleep mode, some apps may be paused or even terminated to conserve battery life, which could be causing the issue you're experiencing with Chatty.
One possible solution you can try is to go into your phone's settings and make sure that Chatty is allowed to run in the background, even when your phone is in sleep mode. This will ensure that the app can continue to receive and process incoming messages even when your phone is in a low-power state.
07-18-2023, 07:21 AM
(01-30-2023, 11:36 AM)user641 Wrote: Hello, I have been using chatty for jabber, but there's this thing that after the phone goes into suspennd mode, the incoming messages cannot be decrypted. Is there a fix for that? What Chatty version are you using and could you describe more detailed what happens? Are incoming messages not decrypted completely after suspend or will you see them if you reboot? (Upper answer does not help you because you can't leave anything running in the background with PP when you suspend. It just suspends all expect modem )
(07-18-2023, 07:21 AM)alaraajavamma Wrote:(01-30-2023, 11:36 AM)user641 Wrote: Hello, I have been using chatty for jabber, but there's this thing that after the phone goes into suspennd mode, the incoming messages cannot be decrypted. Is there a fix for that? i was running version 0.7.0 on mobian, now 0.7.2 on pmos and same problem...messages arrived after suspend never get decrypted, even after reboot.
07-18-2023, 10:43 AM
(07-18-2023, 07:55 AM)user641 Wrote: i was running version 0.7.0 on mobian, now 0.7.2 on pmos and same problem...messages arrived after suspend never get decrypted, even after reboot. Unfortunately it looks like your options are more or less these: Don't use encryption or Stop using Chatty as xmpp client and use Dino instead or Build latest Chatty from git and hope for the best (but expect that it will not work so you wont get too hyped )There are several issues open and it seems that encryption is not working reliable https://source.puri.sm/Librem5/chatty/-/...ge_size=20 |
| Alarm clock doesn’t work | Captain1ndustry | 14 | 30,322 |
12-23-2025, 12:12 AM Last Post: biketool |
| Mobian, Suspend, and Audio Playback | biketool | 0 | 2,904 |
12-11-2024, 12:56 AM Last Post: biketool |
| Suspend functionality broken? | grump_fiddle_reinstall | 4 | 4,402 |
12-05-2024, 08:03 PM Last Post: Kevin Kofler |
| Unable to wake up from suspend | xavi92 | 6 | 7,634 |
07-28-2024, 02:48 PM Last Post: dchang0 |
| Chatty Matrix Decryption Key | jojuma | 2 | 3,720 |
02-26-2024, 12:48 PM Last Post: tophneal |
| Jabber with chatty | user641 | 2 | 4,152 |
11-12-2023, 02:10 AM Last Post: user641 |
| Suspend on ram | user641 | 2 | 3,648 |
09-25-2023, 01:44 PM Last Post: user641 |
| System won't suspend due to suspention notification | user641 | 6 | 8,643 |
09-24-2023, 05:47 AM Last Post: user641 |
| wwan0 (SIM interface) doesn't work with OpenVPN | nickolas | 6 | 7,757 |
09-05-2023, 11:16 AM Last Post: nickolas |
| Power Consumption on Suspend | JudgeFudge | 8 | 8,526 |
07-29-2023, 06:24 AM Last Post: JudgeFudge |
