Upgrade Fedora from 37 to 38?
Does anyone know if it's possible to upgrade Fedora from 37 to 38? I'm running Fedora 37 on an SD card. It's slow but it works.
The built in software manager GUI gives me an error when it tries to upgrade.
I'll read up on the CLI method. I'm asking in case it isn't possible in this particular case or if someone has experience with it.
Thanks!
i'd upgraded my SD install of Fedora from 33 to 34 to 35 to rawhide over the years without any issue. you should be good performing that through CLI.
(07-10-2023, 07:40 AM)tophneal Wrote: i'd upgraded my SD install of Fedora from 33 to 34 to 35 to rawhide over the years without any issue. you should be good performing that through CLI.
While using the CLI to upgrade, I found "the problem". Some of the 3rd party software repositories I added in the GUI were giving errors, "not found" and such. When I disabled those repositories, the upgrade with the GUI worked.
Before I did this, the GUI was failing silently.
Not super good GUI programming then.
Fedora 38 feels noticeably slower than 37 did.
  Fedora 37 installation gswatkins 16 20,767 03-16-2024, 03:09 PM
Last Post: michel_luc
  Fedora 36 -> 37 upgrade kills system tydeman 0 2,478 10-28-2023, 09:53 AM
Last Post: tydeman
  upgrade problem trying4firstbass 1 2,884 11-28-2022, 01:44 AM
  Fedora Workstation (36) on Pinebook Pro u974615 13 20,693 09-02-2022, 11:24 AM
Last Post: u974615
  No audio on Pinebook Pro with Fedora? foobar 1 4,614 08-22-2022, 12:12 PM
Last Post: snorwood
  Fedora 33 to 34 upgrade issues tydeman 2 6,756 12-02-2021, 02:43 AM
Last Post: linuxfreund
  setting up fedora from minimal install pine76 0 4,336 11-30-2021, 10:47 AM
Last Post: pine76
Question Can't boot any operating system other than Fedora after following the nullr0ute guide TDC_PBP 1 5,944 10-09-2021, 07:35 PM
Last Post: TangoZuluTango
  Sound stuttering on Manjaro gnome after latest kernel upgrade? pjsf 0 4,587 07-13-2021, 10:37 PM
Last Post: pjsf
  Some little things to help Fedora users ccunix 0 4,250 05-22-2021, 06:32 AM
Last Post: ccunix
