Firefox issue with latest update
After updating Manjaro on my PinePhone Pro, touch input to Firefox no longer works in portrait mode. Does anyone else see this issue?
This is specific to firefox-108. I downgraded to firefox-107 and it works fine.
(01-09-2023, 06:55 PM)Barugon Wrote: After updating Manjaro on my PinePhone Pro, touch input to Firefox no longer works in portrait mode. Does anyone else see this issue?
Same here on the non-pro PinePhone running manjaro phosh.  Downgrading to 107 also fixed the problem for me.
Hopefully this will be resolved in Firefox 109.
Unfortunately, according to Manjaro ARM, it does not. The latest testing update includes Firefox 109, and this is still in the known issues. They do not expect it to be fixed upstream, neither in Firefox nor in mobile-config-firefox (which comes from PostMarketOS):
Quote:Touch input on Firefox with Phosh not working in Firefox 108
Since the update to Firefox 108, the touch input does not work. Seems to be an issue with a couple of the changes the mobile-config brings in. PostMarketOS likely won’t fix this in their source, so we might need to carry a patch for this.
So Manjaro ARM expects to have to fix this themselves, and so far that has not happened yet.
You can either try to tweak the mobile-config-firefox CSS file yourself with the workarounds from https://gitlab.com/postmarketOS/mobile-c.../issues/48, or downgrade Firefox to 107, or try another browser (e.g., Angelfish).
(01-23-2023, 02:52 PM)Barugon Wrote: Hopefully this will be resolved in Firefox 109.
It is not Firefox issue. You can remove mobile-config-firefox and 108 works as it should.
Issue is that mobile-config-firefox is not yet updated to work with 108 Smile
Well, now nothing fits on the screen (and we're up to Firefox 109 now).
Sorry I did not mention that you need to do in terminal:
scale-to-fit firefox on
And then it works Smile. I actually like it better than with mobile-config package
  debugging issue realted to iso image wth extra data eror penguins_rule 3 5,625 06-18-2024, 01:18 AM
Last Post: waderatke
  systemic issue pinephone penguins_rule 3 5,204 04-02-2024, 11:52 AM
  Using too much juice since last update Eugo 20 22,804 03-15-2024, 10:09 AM
Last Post: Eugo
  recent update Uturn 14 14,347 02-13-2024, 01:19 AM
  new PinePhone upgrade issue WhiteHexagon 5 8,056 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Internal Microphone issue during calls Viktor 6 8,913 03-31-2023, 08:58 AM
Last Post: Viktor
  Latest update Eugo 21 25,260 03-09-2023, 05:27 AM
Last Post: Eugo
  New issue with phone calls kmsgli 13 19,136 08-15-2022, 01:45 PM
Last Post: Gon
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 54,977 07-28-2022, 12:40 PM
Last Post: johaennessen
  Call waiting issue kmsgli 22 34,484 06-24-2022, 06:02 PM
Last Post: kmsgli
