PineBook Pro shuts down immediately after booting
Exclamation
I'm not a heavy user of my PineBook Pro, but I turned it on today and it boots, displays a login screen, and then turns itself off within a minute.
The battery should be full, although the machine doesn't stay up long enough to actually log in and check things.
Any ideas on (a) what went wrong, and (b) how to recover?
Thanks,
Eric
What Linux distribution and bootloader are you using?
Is the main installation running from the sdcard/eMMC/NVMe?
Is the device actually shutting down or going into sleep/suspend mode?
PinePhone, Pinebook Pro & PineTab2 owner.
(12-28-2022, 03:02 PM)dachalife Wrote: What Linux distribution and bootloader are you using?
I'm running Manjaro Linux, using the (I assume) standard bootloader, running from eMMC.
I'm pretty sure it's shutting down, as, if I can log in within a minute, the PBP displays something on the order of "shutting down now".   If I don't log in quickly enough, the power LED turns off entirely.
One thought that I've had is that the battery might be failing; my PBP is fairly old.
Mine also shuts down when I'm drawing too much power (extra drive)/low battery; normal.
No issues when the power adapter is connected? As soon as I plug in it's fine.
I wonder if you can get to the point where you can get Manjaru to tell you what the battery voltage is. Also, in Manjaru, can't you escape the normal multiuser boot with F2? If so, you might get more time to work, and might even not get an automatic shutdown.
I wonder if your charger has stopped working. Sometimes to get a low battery to accept a charge, you must charge it with a USB-C cable.
Beyond that, I hate to suggest it, but it might be worthwhile for troubleshooting to use the bypass cables. Do take care if you do.
:wq
Mine developed exactly the same symptoms. I noticed the red LED going blinky, which the documentation says indicates battery overheating. The obvious solution to that is a battery replacement, but finding one in Canada becomes the next problem.
The shop lists them, but only for the US.
Searching on WTL2020070000001 turns up some 800mAh units with different alpha prefixes than WTL.
How can I tell if they are compatible?
  Video Editing Is Possible On The PineBook Pro! ImmyChan 11 17,324 Yesterday, 12:25 PM
Last Post: elizabethtaylor
  Updated Pinebook Pro? tantamount 2 2,652 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,431 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,974 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,652 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 7,127 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 11,081 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 2,178 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 9,056 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 5,405 06-28-2025, 01:25 AM
Last Post: Www
