Help installing Manjaro on eMMC of Pinebook Pro
Hello
Bought new Pinebook Pro, while updating I logged out and crashed login window theme software, I type the password and then it logs me in then logs me out back to login window, so to reinstall Manjaro I burned Manjaro on SD card and booted from that successfully. Manjaro installed itself on another partiton on SD card rather than eMMC, I then followed some tutorial and used a command to install Manjaroo in eMMC while running from SD card, Now I boot into uboot, some text shows up and now it wont boot from from neither SD card like it used to be able to, and not from USB drive. I used Balena etcher on ubuntu to burn the images on SD card and USB drive but both are not booting.
What shall I do to install Manajaroo in eMMC? I used to be able to boot from SD card using  Manjaro-ARM-kde-plasma-pbpro-22.12.img but not anymore. Now it just loads uboot and then goes to black screen forever.
Thanks in advance.
Rather get some other OS ...
Big Grin
I figured it out. I used the Manjaro image from the wiki and that worked fine and it booted from sd card. Then I used the Arm Flasher to flash eMMC and its working now Big Grin
(12-31-2022, 12:18 PM)pine4546464 Wrote: I figured it out. I used the Manjaro image from the wiki and that worked fine and it booted from sd card. Then I used the Arm Flasher to flash eMMC and its working now Big Grin
Any chance you remember how you did this, I'm in a similar situation. I can boot to Manjaro from sd card but can't figure out how to flash the eMMC
I would like to know which guides he followed also. I just recently managed to brick my install after a major update on Manjaro. Thankfully, I had the Emmc reader this time from the pine64 store, and I was able to backup my files from the emmc, and re-flash it.
  Boot Order in Pinebook Pro food 12 19,056 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,477 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,224 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,651 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,342 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,457 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,633 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,751 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,448 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 4,171 03-08-2024, 08:41 AM
