The 6 most common reasons why Pine64 won't boot
#61
(05-27-2016, 12:00 AM)eddyp Wrote:
(03-31-2016, 11:15 AM)Andrew2 Wrote: I explained the reason several times in the forums why Android images 'need' Phoenix card (the data partition somewhere inside will be resized to the medium's maximum capacity) and also how the Pine64 folks could deal with: prepare a bunch of dd-able Android images with fixed sizes: 7.5, 15.5, 31.5 and 63.5 GB. Or by expanding the partition on first boot -- that's easy with Linux but maybe not with Android. No idea since I'm not interested in Android at all Smile
It sounds like depending on a Windows host could be easily eliminated. It shouldn't be hard enough to make a shell script that could do the writing of the small image then increase the FS to the needed capacity (or simply make the FS big from the start and loopback mount the partition from the image and rsync the contents from the image to the big FS).
I see you said you're not interested in this, but hasn't anybody tried this yet?
On a related topic, is the format of the Pine64 compatible images documented somewhere? I am thinking of trying other OSes than Linux or Android, so this information would be crucial to be able to do this.
Fixed-sized dd-able Android images are already available via the Pine64 wiki.
#62
Tried different images, none boot.  Windows 10 Pro using Phoenix Card 3.1.0.  I chose startup option on the Phoenix Card software.  Allwinner processor starts to get hot and I have to remove power.   Is my board defective?  I just received it a couple days ago.  A64-DB -2G -Rev B dated 2106-03-21.
I am using HDMI so I burned the HDMI Android 5.1.1 release.  Also tried Remix OS same issue won't boot.
#63
(06-06-2016, 10:45 PM)pcfr33k Wrote: Tried different images, none boot.  Windows 10 Pro using Phoenix Card 3.1.0.  I chose startup option on the Phoenix Card software.  Allwinner processor starts to get hot and I have to remove power.   Is my board defective?  I just received it a couple days ago.  A64-DB -2G -Rev B dated 2106-03-21.
1) Burn a linux image
2) disconnect everything except for ethernet // power the Pine on
3) watch for LED activity on ethernet ports / see if the red power LED stays solid
4) see if you can ssh into the Pine
You can always swing by the chat - someone will help you troubleshoot.
#64
Got it to work with a linux image burned on Windows 10 Pro using Win32DiskManager.  That needs to go on Wiki BTW.  Some people may not want to burn a Linux image in Linux!!
Now we need to know why RemixOS and Android 5.1.1 burned in Phoenix will not work.  Can I use Win32DIskManager to burn those images as well?
On the Pine64 Software Release part of the wiki, DD images are for Win32DiskImager and there are also images labelled as being for PhoenixCard.
RemixOS for PhoenixCard:
http://files.pine64.org/os/remix/remix-v...ixCard.zip
RemixOS for Win32DiskImager (8GB image):
http://files.pine64.org/os/remix/remix-v...64-8GB.zip
Android for PhoenixCard:
http://files.pine64.org/os/android/andro...ixCard.zip
Android for Win32DiskImager (8GB image):
http://files.pine64.org/os/android/andro...64-8GB.zip
#66
Thanks.  I have the 32gb card so will any of those links work?  They all say 8gb?
My mistake I see 8 to 64gb in the links sorry about that.
#67
My PINE64 boots fine but outputs a video signal on the HDMI port that won't let DVI and DisplayPort monitors work. I can ssh to it and it works fine, just no video.
I do not want to go out and buy a cheap HDMI television just to use my PINE64, but I'm certain there is a kernel setting that needs to change.
All the other Allwinner boards work fine with HDMI-to-DVI cables after changing a few settings.
Now that everyone is finally receiving their boards we'll get more and more reports of nonworking video which will force a solution.
#68
Nope none work with 32Gb card.  Only ones that work are linux since they work on a range of the size of the card.  The links you listed are for the 8gb sdcard.  Do you have images of all those links for the 32gb card to burn with Win32DiskManager?
#69
RemixOS for Win32DiskImager (32GB):
http://files.pine64.org/os/remix/remix-v...4-32GB.zip
Android for Win32DiskImager (32GB):
http://files.pine64.org/os/android/andro...4-32GB.zip
Android for Win32DiskImager (32GB, ROOTED):
Android for Win32DiskImager (LCD Touchscreen version, 32GB):
Android for Win32DiskImager: (LCD Touchscreen version, 32GB, ROOTED):
#70
(06-08-2016, 01:05 AM)Ghost Wrote: RemixOS for Win32DiskImager (32GB):
I just don't know why but the RemixOS is not booting and the processor gets too HOT!! If I left it in that state I bet it would burn!!
The only ones that boot so far is  Debian Linux Jessie that is it!!
Something must be happening to the bootloader  or kernel during the burn process to my Scandisk Extreme Pro 32Gb.  That MicroSD works perfectly on all my other devices, Raspberry Pi 3, Pi2, DragonBoard and LinkSPrite PCDuino. I also checked the SD card with the H2testw no problems.
Has anyone tested these 32Gb releases burning with WinDiskManager and to see if Pin64 2GB version boots?  Why would the processor continue to get warmer and even hot when its not booting up correctly?
  Having trouble reading MPU6050 sensor via I²C on Pine64 Jaxon 3 8,777 10-21-2025, 10:13 AM
Sad PINETAB-V doesn't boot. FEC 1 2,466 08-23-2025, 02:58 PM
Last Post: Woazboat
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 3 5,131 12-10-2024, 07:23 PM
Last Post: Dendrocalamus64
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 2,415 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 3,092 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 3,848 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 2,841 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,157 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 5,918 06-17-2021, 05:35 AM
Last Post: kqlnut
  How to boot from SD card on pinebook pro linux123 3 9,148 12-02-2020, 10:29 AM
Last Post: linux123
Users browsing this thread: 8 Guest(s)
