When are we getting Geary back?
(11-20-2022, 04:40 AM)Anna Wrote: Is there any feasible alternative? (i.e. something that is not command line based or that's only usable on bigger screens)?
Best, A.
I'm using sylpheed. Do no fit very well, but with the screen at 150 - 175 % and separate folder tree, is useful enough for me.
On Arch Geary works fine, meanwhile you can follow here: https://tracker.debian.org/pkg/geary
(11-20-2022, 06:46 AM)wibble Wrote: Claws used to be usable on the openmoko, but the resistive touchscreen was better fro precision than the capacitive ones are now. Worth a try if you don't mind the appearance.
Unfortunately, claws has also been dropped from bookworm.
Geary 43.0 rolled into bookworm today. I haven't tried it yet.
(12-06-2022, 01:12 PM)treebeard Wrote: Geary 43.0 rolled into bookworm today.  I haven't tried it yet.
Thank you. I was using flatpak Geary on Mobian the last few weeks and to my surprise, uninstalling the flatpak and re-installing Geary from repo kept my config and working fine.
Great, thanks.
Installed it via apt, everything works, I did not even have to re-enter the settings and account details.
  packages held back user641 7 7,603 09-18-2023, 03:05 PM
Last Post: diederik
  Wifi issue since last update and held back updates goku499 11 15,072 09-21-2022, 02:39 PM
Last Post: Katsujinken
  geary shulamy 2 4,062 09-10-2022, 03:01 AM
Last Post: shulamy
  How to move Firefox address bar back to top? Zebulon Walton 5 7,551 06-11-2022, 09:41 AM
Last Post: iwakura_lain
  Geary: can't write mail jsch 2 3,865 03-12-2022, 03:28 AM
Last Post: jsch
  Packages being kept back user641 2 4,265 02-08-2022, 05:34 PM
Last Post: user641
  Protonmail in Geary tombull 1 4,681 11-14-2021, 07:42 AM
Last Post: d-.-b
  need my usb tethering back HLing 12 18,182 08-02-2021, 10:13 AM
  Protonmail in geary r7s3TgmyQv2R3z 1 4,938 03-18-2021, 02:32 PM
Last Post: user12345
  Geary crashes during start after recent update p1trson 2 6,365 01-16-2021, 04:49 AM
Last Post: p1trson
