DietPi OS for Quartz64
[Image: dietpi-logo_192x192.png]
DietPi is an extremely lightweight Debian-based OS. It is highly optimised for minimal CPU and RAM resource usage, ensuring your Pinebook always runs at its maximum potential.
Use dietpi-software to quick and easy install a desktop and lots of other Ready to Run & Optimised applications for your system. DietPi will do all the necessary configurations, including starting the services.
DietPi images are available for PINE A64, PINE H64, Pinebook, Pinebook Pro, ROCK64 and ROCKPro64 and all Quartz64 models.
Our Quartz64 images ship with Linux and U-Boot builds based on latest mainline sources.
Kernel config: https://github.com/MichaIng/DietPi/blob/..._defconfig
Website: https://dietpi.com/
Download images: https://dietpi.com/#download
Documentation: https://dietpi.com/docs/
Blog: https://dietpi.com/blog/
Forum: https://dietpi.com/forum/
GitHub repository: https://github.com/MichaIng/DietPi
DietPi is a free and open-source project. We are be happy if you consider to contribute or donate: https://dietpi.com/contribute.html
Hello, I downloaded latest Bullseye and Bookworm images today for Quartz64A. None of them booted (I used an SD Card, 16GB, balenaEtcher on a Mac ; had no problems with other distress using same process). I was wondering if there were previous images available for download in case one of them would boot?
From my standpoint DietPI seems to be the best available distro for my new SBC, I really wish I could find an image that boots...
(03-06-2023, 10:54 AM)mig Wrote: Hello, I downloaded latest Bullseye and Bookworm images today for Quartz64A. None of them booted (I used an SD Card, 16GB, balenaEtcher on a Mac ; had no problems with other distress using same process). I was wondering if there were previous images available for download in case one of them would boot?
AFAIK the Quartz64 is pretty much a developer device, so UART is a bare minimum here. Would suggest to read through https://forum.pine64.org/showthread.php?tid=17131
(03-06-2023, 04:11 PM)fxc Wrote: AFAIK the Quartz64 is pretty much a developer device, so UART is a bare minimum here. Would suggest to read through https://forum.pine64.org/showthread.php?tid=17131
Thanks @fxc , I am using Armbian (which has a few issues of its own, including not detecting the total amount of RAM). But really my question was about downloading previous DietPI images -- or perhaps building my own?
(03-08-2023, 04:52 AM)mig Wrote:  including not detecting the total amount of RAM
https://forum.pine64.org/showthread.php?...#pid116337
@mig
The latest images do boot, right? There were faulty builds up for some days with a faulty SPL DDR blob update.
@fxc
It is actually quite stable in the meantime, with pretty much complete mainline Linux support. I'm impressed how well everything works when we recently moved to latest upstream Linux kernel builds. Only U-Boot has no native support yet, so we're still using the patched sources by Peter Geis. But I'm in the process of rebasing those on more recent U-Boot versions, which eliminates at least some of the patches.
I booted DietPi onto an SOQuartz yesterday. No problem.
I don't (yet) know how to turn on SPI, I2C etc, but the boot/install process was seamless.
H
(03-26-2023, 03:29 AM)hughsheehy Wrote: I booted DietPi onto an SOQuartz yesterday. No problem.
H
And if anyone can point me at how to turn those on, that'd be greatly appreciated.
H
H
H
Anyone?
H
H
Anyone?
You'll have to use device tree overlays for that, but I don't think DietPi supports those.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
  USB on Quartz64 Zero litbulb 1 2,897 07-22-2026, 02:04 PM
Last Post: MichaIng
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 18,980 03-07-2026, 04:21 PM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 2,662 07-30-2025, 07:19 AM
Last Post: pugzarecute
  Armbian and LibreELEC and AltLinux for Quartz64 balbes150 152 191,807 03-23-2025, 01:10 AM
Last Post: balbes150
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 94,025 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 6,083 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 4,893 07-20-2023, 10:44 PM
Last Post: beepy
  crux-arm Quartz64 RK3566 (aarch64) mara 5 11,608 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 4,329 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 59,862 03-17-2022, 06:29 AM
