Latest update broke my install
Just update my pp a few minutes ago and now it's stucked at arch penguim loading forever
This happened to me last week when I was away, so I couldn't even SSH in.
I looked yesterday and it was missing a .so for libgnome session or something. Sorry I forget now. Anyway, I didn't have the package in the cache so couldn't downgrade to test it. I've stuck my trusty PMOS SD card in the phone for now until I've got the energy to tackle it!
Arch Phosh (PP); firmware: 0.7.1; ADSP: 003
I've just had another look at this after a full update...
Nov 15 10:04:56 pine64 phosh[3557]: /usr/bin/phoc: error while loading shared libraries: libgnome-desktop-3.so.19: cannot open shared object file: No such file or directory
gnome-desktop owns
/usr/lib/libgnome-desktop-3.so /usr/lib/libgnome-desktop-3.so.20 /usr/lib/libgnome-desktop-3.so.20.0.0
Downgrading gnome-desktop didn't work as I don't have old enough packages in the cache. I also tried combos of phosh and phoc with it but have limited older copies.
I had to symlink just to be able to successfully load the desktop...
ln -s /usr/lib/libgnome-desktop-3.so.20.0.0 /usr/lib/libgnome-desktop-3.so.19
But "Settings" fails with
error while loading shared libraries: libgnome-bg-4.so.1: cannot open shared object file: No such file or directory
So more symlinks...
ln -s /usr/lib/libgnome-bg-4.so.2.0.1 /usr/lib/libgnome-bg-4.so.1 ln -s /usr/lib/libgnome-rr-4.so.2.0.1 /usr/lib/libgnome-rr-4.so.1
Other things may fail to run as well but for now I can use my phone. Obviously it is not advisable to symlink system libraries but I have no option at this moment and will revert them as soon as is possible.
Is nobody else having this issue with a fully updated Arch?
[quote pid="114333" dateline="1668510175"]
is nobody else having this issue with a fully updated Arch?
[/quote]
I am having troubles. Every time my PPP suspends due to inactivity, it won't wake the screen again.
Blue LED in upper left corner blinks steadily. The volume buttons still work, I can hear them and it'll ring and give notifications. Power button holding will restart it; and it'll work til sleep again.
I've tried adjusting Settings to prevent it from Power Saving to no avail.
Gnome loads, everything works normal. I just cannot let it sleep.
My problem was worse, I could not even start the phone. In the end I just reflashed, now all updated and working fine.
Ok, my bad, I forgot I was using the testing repo Confused
I reverted my symlinks and re-installed the normal repo version of phoc and phosh, all is working again.
However, I kept the updated versions of eg25-manager and modemmanager Big Grin
Apologies for the noise.
(11-03-2022, 02:53 AM)user641 Wrote: Just update my pp a few minutes ago and now it's stucked at arch penguim loading forever
I'm grateful for this tread as I was wondering whether to update my Archlinux system. I now know not to.
I'm using my PinePhone as my main phone - not recommended I know, but my Nexus 5 (UBPorts) is failing. I think I must have tried almost all the distributions so far and although Arch Linux Posh is a bit quirky, on the PP, all normal phone functions work for me.
Installed archlinux-pinephone-phosh-20220729
PinePhone 2gb/16gb
PinePhone Beta 2GB/16GB Arch Linux ARM danctnix from3 Oct 2025
(was Postmarket OS v24.12)
PineTab2 Arch Danctnix 6.4.2
PinePhone 2gb/16gb
Keep your system up to date, if something goes wrong search for solution or reflash.
(01-01-2023, 10:56 AM)user641 Wrote: Keep your system up to date, if something goes wrong search for solution or reflash.
I have. I'm now on Manjaro Phosh most of which is working.
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 3 10,114 01-09-2025, 05:02 AM
  Pinephone with KDE Plasma stuck at K logo after update Daniello 0 2,199 06-20-2024, 01:52 AM
Last Post: Daniello
  How to install arch with FDE user641 3 5,854 01-11-2024, 10:18 PM
  PPKB certain keys not working after kernel update ragreenburg 20 33,766 06-11-2023, 03:19 AM
Last Post: lectrode
  unable to install applications dln949 5 7,548 06-08-2023, 08:38 PM
Last Post: Conjada
  satellite doesn't work after update shulamy 1 3,924 05-17-2023, 10:34 PM
  new to pacman. Trying to install VIM, getting a 404 when it tries to download. willyray 1 3,914 12-24-2022, 11:00 PM
Last Post: shulamy
  Latest version Arch Plasma looks good. Chief 5 7,416 10-23-2022, 01:53 PM
Last Post: Chief
  Waydroid on Arch Linux ARM install guide? tk1107 3 19,212 10-08-2022, 07:46 AM
Last Post: PineFone
  Help to execute script to install arch with FDE user641 5 9,177 07-03-2022, 09:25 PM
Last Post: RTP
