[Fixed] Phosh crashes frequently after latest updates
The issue seems to be related to https://gitlab.gnome.org/World/Phosh/phosh/-/issues/840 and https://gitlab.gnome.org/World/Phosh/phosh/-/issues/841
glib 2.74 does no longer support G_REGEX_JAVASCRIPT_COMPAT whereas phosh was build with using that regex type/module
So we have to wait for a newer phosh release (or one compiled with a different flag?) before it's safe to upgrade libglib2
(09-22-2022, 11:20 AM)jsch Wrote: The issue seems to be related to https://gitlab.gnome.org/World/Phosh/phosh/-/issues/840 and https://gitlab.gnome.org/World/Phosh/phosh/-/issues/841
Downgrading the three liglib2 packages did the trick - thanks a million!
And to keep these packages even after the next update, it is neccessary to mark the packages on hold like this
sudo apt-mark hold libglib2.0-0 libglib2.0-bin libglib2.0-data
Type unhold for updating, when the issue with Phosh is solved.
Cheers!
(09-22-2022, 12:55 PM)arno_nuehm Wrote: Downgrading the three liglib2 packages did the trick - thanks a million!
I would like to know how to do that please.
Thank you very much!
jsch posted the solution:
wget http://snapshot.debian.org/archive/debian/20220831T091202Z/pool/main/g/glib2.0/libglib2.0-bin_2.73.3-3_arm64.deb http://snapshot.debian.org/archive/debian/20220831T091202Z/pool/main/g/glib2.0/libglib2.0-data_2.73.3-3_all.deb http://snapshot.debian.org/archive/debian/20220831T091202Z/pool/main/g/glib2.0/libglib2.0-0_2.73.3-3_arm64.deb sudo dpkg -i libglib2.0-0_2.73.3-3_arm64.deb libglib2.0-bin_2.73.3-3_arm64.deb libglib2.0-data_2.73.3-3_all.deb
If you want to get updates run again, you have to downgrade three other packages:
wget https://repo.ialab.dsu.edu/debian/pool/main/g/gobject-introspection/libgirepository-1.0-1_1.73.0%2Bds-1_arm64.deb https://repo.ialab.dsu.edu/debian/pool/main/g/gobject-introspection/gir1.2-glib-2.0_1.73.0%2Bds-1_arm64.deb https://repo.ialab.dsu.edu/debian/pool/main/g/gobject-introspection/gir1.2-freedesktop_1.73.0%2Bds-1_arm64.deb sudo dpkg -i libgirepository-1.0-1_1.73.0+ds-1_arm64.deb gir1.2-glib-2.0_1.73.0+ds-1_arm64.deb gir1.2-freedesktop_1.73.0%2Bds-1_arm64.deb sudo apt-mark hold libgirepository-1.0-1 gir1.2-glib-2.0 gir1.2-freedesktop
After this, updates should work again...
Thumbs Up
Thank you jsch !
Thank you arno_nuehm !
You have saved the day! Smile
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
It works anew. I updated and upgraded about 3 hours ago, I have no longer any crash.
I ran updates today after about a week and all seems to be OK as well. I did a full image backup first just in case, then ran update, upgrade, and dist-upgrade. I checked to see if dist-upgrade was going to clobber anything like when it removed the "Settings" program a little while ago and nothing looked dangerous. Rebooted and as far as I can tell nothing is amiss. Phosh is stable, nothing seems to be missing, address book looks OK, and the phone can make calls.
Confirmed, after I did:
sudo apt-mark unhold libglib2.0-0 libglib2.0-bin libglib2.0-data sudo apt update sudo apt upgrade sudo apt dist-upgrade
...and rebooted, everythings back to normal! Smile
Can confirm, too.
Had to unhold the three other libg2 packages.
Marking as solved.
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,595 01-15-2025, 08:08 PM
  Auto start application on Phosh login Zebulon Walton 8 13,288 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  No volume control after latest updates Zebulon Walton 19 22,109 09-08-2023, 08:28 AM
Last Post: jessencan
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 18,470 08-31-2023, 12:38 PM
Last Post: vusra
  Haven't seen updates in a while Zebulon Walton 3 5,366 06-24-2023, 04:29 PM
  Using sway along phosh fdlamotte 2 6,397 05-11-2023, 04:24 PM
Last Post: kabouik
Exclamation Impossible to login since the latest update anonymous 12 17,181 02-26-2023, 01:01 PM
Last Post: anonymous
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 5,409 02-24-2023, 12:11 AM
Last Post: nexion
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 14,314 11-28-2022, 03:30 PM
  Latest Reliable Mobian Build Confirmation Thread Katsujinken 5 7,770 09-27-2022, 08:41 AM
Last Post: Katsujinken
