Haven't seen updates in a while
It's been at least a week since I've seen any Mobian updates. Just tried again, but there's still nothing.
[root@mobian apt]$ apt-get update && apt-get upgrade Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://repo.mobian-project.org bookworm InRelease Reading package lists... Done            Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Does something need to be changed in /etc/apt/sources.list? Currently mine looks like this:
deb http://deb.debian.org/debian bookworm main non-free contrib non-free-firmware
There is also a file /etc/apt/sources.list.d/extrepo_mobian.sources which contains:
Uris: http://repo.mobian-project.org/ Components: main non-free Types: deb deb-src Architectures: amd64 arm64 armhf Suites: bookworm Signed-By: /var/lib/extrepo/keys/mobian.asc
In a sense I'm not really complaining since the phone is working pretty well for my purposes and updates can go wrong. I'm just hoping that they may eventually fix some of the rough edges.
(06-24-2023, 01:10 PM)Zebulon Walton Wrote: It's been at least a week since I've seen any Mobian updates. Just tried again, but there's still nothing.
That's what we call Debian stable, you know,it's stable Smile))
See https://blog.mobian.org/posts/2023/06/10/bookworm/
basically you need to choose between bookworm and trixie, https://blog.mobian.org/posts/2023/06/10/bookworm/ .
if staying with bookworm, then bookworm-security is needed.
this is my fresh mobian bookworm installation after release.
# if bookworm mobian@mobian:~$ cat /etc/apt/sources.list deb http://deb.debian.org/debian bookworm main deb http://security.debian.org/ bookworm-security main mobian@mobian:~$ cat /etc/apt/sources.list.d/mobian.list deb http://repo.mobian.org/ bookworm main non-free-firmware
(06-24-2023, 01:39 PM)mdk Wrote: That's what we call Debian stable, you know,it's stable Smile))
RIght! Smile However this is the first time I've seen no updates for any length of time. Probably because Debian 12 is now officially released, hadn't thought of that.
(06-24-2023, 01:41 PM)zetabeta Wrote: basically you need to choose between bookworm and trixie, https://blog.mobian.org/posts/2023/06/10/bookworm/ .
Thanks, I'll probably stay with "stable" unless I hear one of the issues I'm still seeing (like no volume control on calls and bluetooth audio not working) is supposed to be fixed. (I did try pipewire - volume controls worked but audio routing was totally screwed up, so I went back to pulseaudio.)
I'll update my apt sources to include bookworm-security.
  No volume control after latest updates Zebulon Walton 19 22,355 09-08-2023, 08:28 AM
Last Post: jessencan
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 18,707 08-31-2023, 12:38 PM
Last Post: vusra
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 26,562 10-14-2022, 05:38 PM
Last Post: Krafter
  Wifi issue since last update and held back updates goku499 11 16,331 09-21-2022, 02:39 PM
Last Post: Katsujinken
  Glacially slow system updates on Mobian - waiting on boot 20m - 1h bujiraso 5 8,499 03-01-2022, 10:06 AM
Last Post: bujiraso
  No updates after upgrade? jojuma 3 5,717 08-26-2021, 08:53 PM
Last Post: bcnaz
  "Unable to download updates: The following packages have unmet dependencies:" bitnick 13 22,891 04-23-2021, 09:45 PM
Last Post: ryo
  Issues with Mobian 20210314 (data and updates) IMSAI8080 5 11,267 03-20-2021, 04:14 AM
Last Post: IMSAI8080
  Stable build and updates ergo owl 3 7,759 09-19-2020, 06:59 AM
Last Post: User 18618
Question Question re updates and nightly images JustineSmithies 1 4,934 06-27-2020, 12:24 PM
Last Post: devrtz
