No volume control after latest updates
Last week I updated Mobian and found that the up/down volume buttons no longer worked either when using the phone's internal earphone or an external wired headset. This evening I updated to the latest, including dist-upgrade which pulled in mobian-base, mobian-phone-base, and gnome-calendar.
After this update not only are the volume controls not working but when I went to test phone operation I received a popup from the contact list saying something like "Cannot find primary phone book". However after using the cancel option in the popup the expected contents were listed and the error message has not been repeated even after rebooting.
Anyone else seeing these issues? The lack of volume control doesn't make the phone unusable and is just an annoyance, but if it comes down to it I have a full image backup made just before the most recent updates. However I'll probably wait and see if the next round of updates fixes this.
Another data point, I just noticed that the volume controls are non-functional only during phone calls. (The slider popup comes up and moves appropriately but the sound level does not change.) However, the volume control works fine when playing media files locally on the phone.
I just did another round of updates and the problem persists. Don't know what to make of this, it's not a deal breaker but definitely an annoyance. Hopefully it will be fixed soon...
initially when i tested this was the case, volume buttons do not work for calls. but i tested again and it now works, i did not update anything in between. however, volume seems to be little logarithmic, on the higher side, difference is very small. on the lower side is audible.
i don't rule out some issues with audio routing though.
Yeah, it's a bizarre problem and annoying. (For now I have to "adjust" the volume by moving the phone closer or further away, or on my wired headset by pulling the earbud partway out.) It's not bad enough though that I want to blow it away by restoring a backup image.
Just brought Mobian up to date today and still no volume controls during calls. Very annoying. Did some web searches but haven't found any fixes for the problem yet.
(11-05-2022, 12:49 PM)Zebulon Walton Wrote: Just brought Mobian up to date today and still no volume controls during calls. Very annoying. Did some web searches but haven't found any fixes for the problem yet.
I had this same with Pulseaudio.
With Pipewire && pipewire-media-session && pipewire-pulse it works Smile
Don't know does it help but worth mentioning
Thanks, I checked and pipewire plus pipewire-media-session were already installed and starting automatically. However pipewire-pulse was not installed. I installed that and rebooted, all three programs started automatically. However that resulted in no sound at all and no response to volume control buttons, not even the on-screen display.  Sad
So I removed pipewire-pulse and rebooted, and fortunately it's back to the way it was - audio works but no volume control during calls.
An up-to-date bookworm should have pipewire, pipewire-pulse, and wireplumber with all 3 services enabled and running. pulseaudio servie should be disabled.  pipewire-media-session should have been removed by the upgrade.
https://wiki.debian.org/PipeWire#Debian_...2FUnstable
(11-07-2022, 02:36 PM)treebeard Wrote: An up-to-date bookworm should have pipewire, pipewire-pulse, and wireplumber with all 3 services enabled and running. pulseaudio servie should be disabled.  pipewire-media-session should have been removed by the upgrade.
Thanks, I'll give that configuration a try and see how it works out.
kinda late here, but I've been doin this:
Quote:systemctl --user restart pulseaudio
it seems to fix the audio issues until you restart the device or power it on after shuttin down. I reinstalled to the September 25th image for the time bein.
  gnome-control-center: segmentation fault on startup jojuma 4 6,248 09-12-2023, 08:49 AM
Last Post: jojuma
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 18,840 08-31-2023, 12:38 PM
Last Post: vusra
  Haven't seen updates in a while Zebulon Walton 3 5,511 06-24-2023, 04:29 PM
Exclamation Impossible to login since the latest update anonymous 12 17,632 02-26-2023, 01:01 PM
Last Post: anonymous
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 14,684 11-28-2022, 03:30 PM
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 26,760 10-14-2022, 05:38 PM
Last Post: Krafter
  Latest Reliable Mobian Build Confirmation Thread Katsujinken 5 7,922 09-27-2022, 08:41 AM
Last Post: Katsujinken
  Wifi issue since last update and held back updates goku499 11 16,490 09-21-2022, 02:39 PM
  Loving latest Mobian Update drh 11 15,193 08-22-2022, 12:19 PM
  Pinephone incoming call / SMS notification no ringing / notification volume dcinoz 3 7,678 06-02-2022, 07:16 AM
Last Post: arkadione
