Pinebook Pro freezes when running on battery
I have a recent Pinebook Pro from September 2022 (motherboard bears a 2022/07 QC sticker)
It has an NVME (low power WD) SSD for /home and data only, and Manjaro Linux KDE runs from the eMMC, with latest updates applied.
When running from mains power, the system is perfectly stable. But the power cable is so short !
OTOH when running on battery, even fully charged, it happens very often (twice attempting to write this post) that the system completely freezes with the power LED blinking red/green.
At this point I can only perform a hardware poweroff.
Any clue ?
Kind regards.
I have a very similar setup, but with the NVMe as the root drive and the eMMC just as extra storage. Low-power WD SSD, Manjaro, KDE -- all the same. I mostly run on battery, even, and have never had this fault.
I can tell you that typically the red-green flashing indicates a kernel panic, so you may be able to check dmesg to see if there's any particular module that is failing.
(09-15-2022, 01:33 PM)steeb Wrote: I can tell you that typically the red-green flashing indicates a kernel panic, so you may be able to check dmesg to see if there's any particular module that is failing.
Well a kernel panic is something so brutal that the system doesn't get a chance to log anything to disk when it happens... It just stops.
I don't know Linux very well but does it output something to the serial console when that happens?
:wq
If you don't think there's anything useful about seeing exactly what was happening at the time of the kernel panic, then all I'll do is wish you good luck. Thanks for the education, though.
It appears that setting the NVMe to maximum power state PS2 fixed the issue, as far as I can tell.
  Pinebook Pro for sale rfm83 0 351 11-08-2025, 09:22 AM
Last Post: rfm83
  Pinebook pro bricked? michaelmoua 3 4,839 10-23-2025, 10:06 AM
Last Post: jceaser
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 6,857 08-02-2025, 08:55 PM
  Pinebook problem meghancordo 1 4,163 07-24-2025, 07:28 AM
Last Post: mikehenson
Question Printing and scanning documents with pinebook? Www 0 3,730 06-28-2025, 01:25 AM
Last Post: Www
  Pinebook Pro in EU for Sale - €90 jan_vdk 4 7,104 06-19-2025, 02:14 AM
Last Post: shelfaberrant
  Use SD to install new OS over pinebook debian Rudy558 10 23,650 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 4,706 02-05-2025, 03:56 AM
Last Post: waylonwesley
  Pinebook Next !spekulation! Surehand53 2 5,610 01-23-2025, 11:49 AM
Last Post: Surehand53
  Pinebook Pro wants a PIN for my bluetooth mouse ColoBill 1 4,215 01-19-2025, 04:38 PM
Last Post: ColoBill
