No audio on Pinebook Pro with Fedora?
I'm currently running Fedora with tow-boot on my Pinebook Pro, and mostly it's working great. One issue I haven't resolved yet that is specific to this distro, is lack of sound. I get the following errors on boot:
Aug 21 18:11:28 fedora alsactl[1161]: alsa-lib main.c:1541:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -2 Aug 21 18:11:28 fedora alsactl[1161]: /usr/sbin/alsactl: set_control:1475: Cannot write control '2:0:0:ALC Capture Target Volume:0' : Invalid argument
I tried installing a kernel with patches from Manjaro via `kernel-pbp` from this Copr repo, but it requires a change to the boot procedure, possibly by uninstalling efi, grub and other packages, then installing the u-boot pacakge from that same repo. I'm tempted to try this, but would prefer not to make such radical changes to the boot process at this time. I did try installing their `pinebookpro-audio` package, but that wasn't enough to solve the issue.
Has anyone had any success with audio on Fedora?
I have the same issue. Don't quote me on this, but I believe that it worked with the default Fedora 36 installation and broke when I yum updated it. I haven't spent any mount of time trying to troubleshoot this, but figured that I'd post to indicate that you are not the only one with this issue.
  Boot Order in Pinebook Pro food 12 18,836 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,400 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,165 08-09-2025, 06:53 AM
Last Post: Sb2024
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,552 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,710 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,405 03-31-2024, 10:11 AM
Last Post: u974615
  Fedora 37 installation gswatkins 16 20,305 03-16-2024, 03:09 PM
Last Post: michel_luc
  Pinebook Pro upgrading from the factory image yamsoup 12 17,677 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,288 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,523 12-11-2023, 03:47 AM
Last Post: calinb
