apt-get update "The following signatures were invalid..."
Try
sudo apt-get dist-upgrade
(07-23-2022, 01:25 PM)ljones Wrote: Can't update here as well. I can't install curl (I get 404  Not found) so I tried using wget above but it makes no difference.
404 Not Found errors on a new install of Mobian are caused by trying to download from an automatically-selected Debian mirror that is incomplete. If you manually choose a Debian mirror (one that is actively maintained) and enter it in /etc/apt/sources.list, you won’t have 404 Not Found errors any more.
This checks out -  you can find a suitable mirror here: https://www.debian.org/mirror/list
The only thing I would add is that you do need to comment out the current listed archive since there seems to be some issue currently with that server.
This worked for me.  You should be able to select whatever mirror is close.
#deb http://deb.debian.org/debian bookworm main
deb http://debian.csail.mit.edu/debian bookworm main
I just read somewhere on mobian's site that apt-get gets you less than just apt, and that apt upgrade is a bit conservative, it won't drop unused stuff, won't install what already wasn't there, that apt dist-upgrade will. Also, it said that the apt-get dist-upgrade combination is most likely to fail a lot.
  No touch KB after update(forky) biketool 4 2,470 12-05-2025, 01:15 AM
  trixie update poll questions suggestions j_s 5 3,000 10-22-2025, 07:14 AM
Last Post: anonymous
  how to update mobian over tor vusra 14 20,317 12-04-2024, 07:01 PM
Last Post: vusra
  Wifi doesn't work after update nickolas 2 4,793 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 4,979 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 16,868 02-26-2023, 01:01 PM
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 13,952 11-28-2022, 03:30 PM
  Wifi issue since last update and held back updates goku499 11 15,735 09-21-2022, 02:39 PM
Last Post: Katsujinken
  [SOLVED] Lost Internet connectivity after recent update drh 3 5,457 09-11-2022, 09:24 PM
  Rescue Your Mobian post Update Aug22 faster fix to working guide biketool 9 14,221 09-05-2022, 12:10 AM
