Armbian and LibreELEC and AltLinux for Quartz64
#41
(05-15-2022, 03:33 AM)shaggy013 Wrote: hdmi > lvds adapter no hdmi
so flashed again moved board to tv
sony 4k etc tv no hdmi
plugged in and out cable nothing
Samsung 1080 tv no hdmi
frokm hdmi 1 cable to hdmi xxx no hdmi
well the dmesg triggers the kernel panic and reboots the device
What is connected to USB ?
(05-15-2022, 04:14 PM)reciu Wrote: Ambian: newest build i cant mount SSD disk via USB 3.0, on 2.0 ports works pretty well. Also cleaning and creating partition doesnt work on 3.0 Sad
USB 3.0 support is not stable yet.
Hey Balbes150
it is not only librelec not 1 mainline distro gives me hdmi output , it boot detects but no go
i got some hdmi output through a different port
2 logs 1 with working port other with higher clocks no hdmi
.log   Xorg.0.log (Size: 22.89 KB / Downloads: 344)
.zip   xorg-sony-log.zip (Size: 10.19 KB / Downloads: 304)
(05-17-2022, 06:39 AM)shaggy013 Wrote: Hey Balbes150
I regularly check the launch of Armbiab\Altlinux\LE with the main core on several monitors and TV (2 monitors and 3 TVs), HDMI works on all (1080p60Hz is auto-detected on all by default). In the latest versions of LE, changing the desktop resolution settings in KODI works, I can set any resolution (1600x1200 1280x1024 800x600, etc.) and it is normally displayed on the screen. The driver developer wrote in the mailing list that he set the 4k resolution and it works for him. I can assume that your hardware is forcibly trying to set incorrect data (unsupported parameters).
Nothing wrong with the tv that is just fine
and sure on port 1 low speed hdmi it works fine , the driver just cant handle high speed hdmi from what i read , and mayby some fixes in the 5.20 kernel
ArmbianTV kernel 5.18 (edge) and 5.17.9 (current)
AltLinux kernel 5.17.9
Libreelec kernel 5.18
Test ArmbianTV ver 20220531-legacy kernel 5.10
ArmbianTV ver 20220603-legacy, fixed HDMI sound
Libreelec kernel 5.18.2
LE kernel 5.18.5
Armbian kernel current 5.17.15 and edge 5.19-rc3
ArmbianTV kernel current 5.18.7 and edge 5.19-rc4
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 16,973 03-07-2026, 04:21 PM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 2,062 07-30-2025, 07:19 AM
Last Post: pugzarecute
  USB on Quartz64 Zero litbulb 0 1,526 11-13-2024, 08:16 AM
Last Post: litbulb
  DietPi OS for Quartz64 MichaIng 47 53,831 08-08-2024, 07:42 AM
Last Post: ifreislich
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 84,430 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 5,107 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 4,078 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 5,172 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 10,398 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 3,766 07-21-2022, 01:08 PM
Last Post: Randomuser
