PineTime Touch Screen Stopped Working
Hello All,
I am running InfiniTime
FW 1.8.0
HW 1.0.0
all had been going well with the watch since I got it until today when the touch screen stopped working. I have been running 1.8.0 since Feb 21. I have tried rebooting by holding the power button, I tried installing the 1.9.0 version on InfiniTime hoping that would reset things but the touch screen still is not working. The power button still works and I can still connect it to Gadgetbridge.  It is a sealed watch so I have no access to the internals.  My current plan is to let the battery die and see if that will reset anything.  Please let me know if you have any recommendations and I will post again if anything changes.
So the battery died then I charged it up and there was no change. Any ideas on what I should try next?
maybe it's make sense to open a ticket under support.pine64.org.
Away
hello. in my case, every time the clock warmed up in the sun, the touchscreen stopped working. heating did not last long. I'm inclined to believe that the touchscreen deteriorates from heating or soldering falls off somewhere inside Sad even from not very high heat (I live in the north and there is no heat here) Sad terribly upset .. two hours out of three died. all sealed and I can't open them.. Sad
  Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 3 5,300 06-06-2026, 03:33 PM
Last Post: oscar-gardiazabal
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 5,197 11-01-2025, 05:55 PM
Last Post: euiccc2025
  Migrating to PineTime from a Fitbit dhdurgee 0 4,383 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 11,346 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 6,333 07-30-2025, 11:44 PM
Last Post: karthick
  PineTime charging issues - connecting pins black gsoundsgood 2 4,538 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 7,396 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 11,711 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 7,518 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 2,966 01-31-2024, 11:57 AM
Last Post: tynstar
