PInebook not booting with eMMC enabled
Right now I have an SD card with Manjaro. If I disable eMMC and press reset, the power led goes red and then pinebook boots to Manjaro from SD. If I enable eMMC and press reset, power led goes off and nothing happens. I did check that eMMC is properly connected. What else can I try?
(10-21-2021, 03:35 PM)aragaer Wrote: Right now I have an SD card with Manjaro. If I disable eMMC and press reset, the power led goes red and then pinebook boots to Manjaro from SD. If I enable eMMC and press reset, power led goes off and nothing happens. I did check that eMMC is properly connected. What else can I try?
You have a "bad" uboot on emmc,, search order for uboot (really idbloader)  is SPI, emmc, uSD
Boot from SD, re-enable emmc, use the bind command (search forum), change uboot on emmc
Tried that -- when I boot and re-enable emmc, it's not visible in the system: /dev/mmc* only shows the SD card. When I try the commands in the https://wiki.pine64.org/index.php/Pinebo...nformation I'm getting "write error: No such device"
When I look in /sys/platform/devices, there is no ff330000.sdhci device, but there is ff330000.mmc device instead. I tried the following commands:
echo ff330000.mmc > /sys/bus/platform/drivers/sdhci-arasan/unbind
echo ff330000.mmc > /sys/bus/platform/drivers/sdhci-arasan/bind
These worked but no effect -- I only got a couple of error messages in dmesg.
I've got me an A-A USB cable to try the recovery process but failed to do that (probably didn't do the sequence right). Instead I tried again to boot with eMMC disabled and enable it once the boot started. I've stopped the U-boot from automatically booting and it showed that eMMC does indeed exist. After that I booted into Linux and did `dd if=/dev/mmcblk1 of=/dev/mmcblk2` (from SD card to eMMC). Rebooted again and it booted from eMMC.
That's good
Really, all you needed to do was copy mbr (1 sector) to sd, dd 1st 16M sd->emmc, restore emmc mbr
If it should be a little 'flakey' a non-booted distro has the /dev, /sys, /proc, /run
directories empty, just the top directories and the kernel fills them with virtual files
So, you may have to boot from sd, mount emmc and empty those directories
I've found mc (as root) the quickest and least hassle
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 260 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 939 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 4,780 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 8,038 02-09-2026, 12:50 AM
Last Post: Anthona
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 722 12-18-2025, 01:05 AM
Last Post: qingss0
  Pinebook Pro for sale rfm83 0 713 11-08-2025, 09:22 AM
Last Post: rfm83
  swap eMMC advice jceaser 2 993 10-23-2025, 09:59 PM
  Pinebook pro bricked? michaelmoua 3 5,316 10-23-2025, 10:06 AM
Last Post: jceaser
  Need new eMMC Karsten1 2 3,065 10-23-2025, 09:38 AM
Last Post: jceaser
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 7,290 08-02-2025, 08:55 PM
