Backing up contacts prior to OS reinstall
Question
Is it possible/practical to backup my contacts somehow, then restore them after I've reinstalled the operating system?
If so, a step-by-step guide to achieving this would be greatly appreciated.
For byte-sized tech and software tips check out my Danimations Digital Media tips channel on Youtube Big Grin
You did not specify the shell - Plasma Mobile or Phosh?
In Plasma Mobile I'm using a combo usbA&usbC memory stick and copy there the following files:
/.config/KDE/plasma-phonebook.conf
and directories:
/.local/share/kpeople
/.local/share/kpeoplevcard
Just with Index file manager
i keep them on my nextcloud, but with KDE plasma mobile, only contacts. For calendar items I must learn vdirsyncer.
With vdirsyncer, you should be able to save your contacts to a local directory too, by the way.
And then sync them back to your new install.
On Phosh the contacts are stored in .local/share/evolution/addressbook. You can just backup and restore that folder.
  How do I import SIM card contacts? Logological 8 15,266 06-04-2023, 12:49 PM
Last Post: mruser1
  nextcloud contacts are duplicating Uturn 1 4,707 10-24-2021, 01:35 AM
Last Post: user641
  How to import contacts into the phone book app? nelstomlinson 8 13,950 07-18-2021, 03:26 AM
Last Post: Gary2003
  A Way to Switch from KDE Plasma to Phosh Without a Reinstall? Old_Mil 1 5,157 07-09-2021, 08:29 PM
Last Post: TRS-80
  Contacts not Importing mdshell 1 4,324 03-30-2021, 02:24 AM
Last Post: acrux
Question Reinstall Geary ? Gary2003 1 3,953 02-20-2021, 10:09 AM
Last Post: Veraendert
