A Way to Switch from KDE Plasma to Phosh Without a Reinstall?
I'm thinking of this in terms of a desktop linux installation where, after installing whatever flavor of linux you wanted to install, you could then apt-get install a variety of front ends like Gnome, KDE, XFCE, and so on...
...is there an easy way from the terminal to download and install phosh or ? without the whole download a new install, put it on the SD card, and wipe the phone?
(07-07-2021, 12:32 PM)Old_Mil Wrote: I'm thinking of this in terms of a desktop linux installation where, after installing whatever flavor of linux you wanted to install, you could then apt-get install a variety of front ends like Gnome, KDE, XFCE, and so on...
I am sure it will get there eventually, just like regular desktop GNU/Linux. However, currently, it is still early days...
(07-07-2021, 12:32 PM)Old_Mil Wrote: ...is there an easy way from the terminal to download and install phosh or ? without the whole download a new install, put it on the SD card, and wipe the phone?
I don't think so.[0] At this time, I suspect it may be easier right now to purchase some additional SD cards. And/or, try out that multi-boot image?
[0] I could be totally wrong. And if that's the case, hopefully my bump helps your post with a little visibility and someone who knows better comes along with a better answer for you.
Cheers,
TRS-80
Protocols, not Platforms
  Wi-Fi Issues (Plasma and Lomiri) PineSupporter 11 22,301 02-20-2026, 12:16 PM
Last Post: krissprat73
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 4,243 07-03-2024, 08:38 PM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 10,577 10-02-2023, 05:07 AM
Last Post: Uturn
  Switch to xfce? jakfish 5 8,968 06-22-2023, 01:37 PM
Last Post: jakfish
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 3,783 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 16,737 03-02-2023, 07:25 PM
  Backup and Home Screen Tinkering on Phosh jakfish 0 2,626 02-24-2023, 12:56 PM
Last Post: jakfish
  Manjaro plasma-mobile Beta 13 Uturn 13 17,329 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 4,865 11-22-2022, 05:00 PM
Last Post: Chief
  MMS workaround for users with separate APN (works atleast on Manjaro Phosh) alaraajavamma 0 3,003 10-10-2022, 12:53 PM
Last Post: alaraajavamma
