Manjaro w/ Panfrost Drivers vs stock Debian Video Performance
see post 4 above
(03-20-2020, 03:45 PM)decisivedove Wrote: Setting the environment variable breaks the game. The graphics don't render. I am running Manjaro with Panfrost drivers.
Yes, you are right. I tried it out, and it seems GLES3 support in panfrost isn't quite there yet. The same is true for firefox with the webrender backend, it shows only some corrupted triangles.
this isn't true at all and i've posted the workarounds already.
https://www.gamingonlinux.com/articles/o...port.16094
They might have added OpenGL ES 3.0 support on Panfrost.
is there a reason you are ignoring the answers to your questions?
(03-24-2020, 11:22 PM)xmixahlx Wrote: is there a reason you are ignoring the answers to your questions?
In your first post, you mentioned that using gles3 it could support graphics quality 2. You also mentioned that you were getting 60 fps in testing. Your answer seemed to imply that you got the game working in gles3.
Maxjrh suggested setting the environment variable PAN_MESA_DEBUG=gles3. I tried that and replied to him that it was not working. You then told me to look at post 4 above. And when he replied, you claimed that you had already posted a workaround. What workaround were you talking about? I could not find the workaround. After researching a little more, I figured out that we had to disable Advanced Pipeline for STK to work in  gles 3. In the link I posted, it mentions to use the non-deferred renderer.
You kept redirecting me to post #4 where I could not find any workaround. I know you were only trying to help. I should have more responsive and tried to get it clarified.
I am sorry that you felt ignored.
  Debian on Pinebook Pro u974615 7 1,043 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 290 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 334 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,764 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 336 01-19-2024, 11:32 PM
  Streaming video sites tessa 1 1,052 01-19-2024, 03:47 AM
Last Post: similarwham
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,157 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,233 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 414 12-07-2023, 03:11 PM
  No Video Out on PBP on all major distros misha64 9 2,819 11-28-2023, 01:41 PM
Last Post: zaius
