Better (than default Debian/MATE) Linux distro?
(02-27-2020, 06:57 AM)Wizzard Wrote:
(02-26-2020, 01:04 PM)mrjay Wrote: Ubuntu 20.04 + tsys source compiled kernel ... very stable and panfrost works.
How can you run Ubuntu 20.04? Can you provide the details and kernel? Thanks!
Kernel from  here: https://gitlab.manjaro.org/tsys/linux-pi.../tree/v5.6
Ubuntu installed via debootstrap: https://wiki.ubuntu.com/ARM/RootfsFromSc...ebootstrap
To test i've installed ubuntu on sdcard then copied files to nvme
Interesting, so you compiled that kernel and whole filesystem? Would you mind sharing that image?
Btw, everything works?
I don't mind sharing the image but i'm just not sure how to create one ... never did it before.
About compiling ... i didn't compiled whole ubuntu just kernel from tsys
Ubuntu is installed via debootstrap to sdcard, compiled kernel is installed to /boot folder on sdcard. i have edited /boot/extlinux/extlinux.conf to boot from sd.
When you install ubuntu on sdcard you can configure it using chroot
Also compiled modules need to be installed to /lib/modules
When all booted ok ... i've booted Ubuntu from sdcard and copied all files to nvme and edited extlinux.conf (root=LABEL=... part)
About last question: Everything works ... kernel is form tsys(Manjaro kernel) so everything it supports ... works.
About 3d ... ubuntu 20.04 uses mesa 20.0 git so 3d is also up to date too
Also tsys started to mainlining his patches so in time we should have mainline kernel working on pbp
https://patchwork.kernel.org/patch/11409463/
Okay, thanks, so can you please share that kernel so other people do not need to compile that?
I never used debootstrap, I can try it, but I am not sure if I am able to compile the kernel.
https://drive.google.com/open?id=1O6_MuQ...f_VlTROlLH
Thanks! If you manage to make also full image file from that installation, that would be great.
Btw, have you flashed some SPI flash to boot from NVMe?
Nope ... u-boot is a "leftover" from previous installs i'm not sure if its on spi or mmcblk
If you have not flashed SPI, it is just on mmcblk. Ok, no problem, so I am not sure if it will work on my modified SPI.
#19
Ubuntu 20.04-alpha1:
https://drive.google.com/file/d/16Tz1F33...sp=sharing
username: pine
password: pine
rootpassword: pine
#20
Thanks! It works. Just installing KDE.
edit: KDE works fine, when I disable compositor.
.png   Screenshot_20200229_205754.png (Size: 59.13 KB / Downloads: 525)
  Debian on Pinebook Pro u974615 7 1,201 03-31-2024, 10:11 AM
Last Post: u974615
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 361 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Nethunter default password failed lamlarryyyy 0 362 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  install debian on pbp jsch 7 4,131 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,583 09-07-2023, 09:38 PM
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,522 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,123 07-15-2023, 02:58 PM
Last Post: u974615
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 674 07-13-2023, 05:21 PM
Last Post: owaspfap
  Kali Linux for Pinebook Pro Luke 100 160,861 05-03-2023, 06:10 AM
Last Post: dachalife
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,294 12-09-2022, 12:43 PM
Last Post: as365n4
