Netflix on default Chromium/Debian
Hi all!
I'm rusty on my linux and I'm trying to watch netflix on it for the first time.
For some reason I thought that in the default distribution provided with PBP the Chromium browser already included support for Netflix. I can't watch it in Chromium nor Firefox. Is there additional setup necessary to get it going? I see that widevine is part of the updates that I run every once in a while so I'm even more confused by it not working.
If anyone could point me to how to get it running on the original distribution, would be appreciated.
Thanks!
(01-23-2020, 09:49 PM)MoonDog Wrote: Hi all!
Thanks!
There is script on the desktop you have to run to install wildvine.  I recommend you run the updater on the bottom of the screen then run the wildvine install script.
(01-23-2020, 10:24 PM)Samarium151 Wrote: There is script on the desktop you have to run to install wildvine.  I recommend you run the updater on the bottom of the screen then run the wildvine install script.
Is the script supposed to be located in /home/rock/Desktop/ ? There is no script in mine. I don't think I erased anything but perhaps that could've happened...
the desktop is just a link to the system script. it is also called widevine.
update_widevine.sh or something similar. open a terminal and use sudo to install.
sorry, I am not using the default os to confirm
(01-24-2020, 01:31 PM)xmixahlx Wrote: the desktop is just a link to the system script. it is also called widevine.
Is there a link to github, or some other repository for this script - it would be useful for other armhf userland installs, besides the stock mrfixit Debian.
I looked, but can't find it.
— Jeremiah Cornelius
When you run the MrFixit script it puts the program on the desktop. I've run it a number of times and it's not working. I'm sure I've done something wrong on my end though.
The only file on the Desktop is one that I created, and I have the latest updates for the PBP applied.
I think actually that widevine is working on my chromium but that for some reason Netflix specifically isn't.  I went to some sites to test the DRM playing capability of the browser and it worked. I think i'll have to update widevine or chromium...
Thanks!
I am a novice. I assume I am supposed to give a command in the terminal to run this script.  Can you please let me know what exactly to type in terminal to install Widevine.
I guess that you use the default debian system. If so you just have to open terminal, you may have on icon near the menu on the bottom-left corner.
After starting a terminal, you should type
update_widevine.sh
I hope you can run it. It seems tha tNetflix don't like this version anymore (I hope it will change soon) . But Primevideo works pretty well for me and even on firefox (Netflix on firefox on PBP)
  Debian on Pinebook Pro u974615 7 1,034 03-31-2024, 10:11 AM
Last Post: u974615
  Nethunter default password failed lamlarryyyy 0 352 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  install debian on pbp jsch 7 4,046 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,431 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,066 07-15-2023, 02:58 PM
Last Post: u974615
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,279 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,341 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,047 10-19-2022, 03:09 AM
Last Post: alpopa
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 1,906 09-23-2022, 08:37 PM
Last Post: computerc
  Debian emmc installer db579 6 2,987 08-23-2022, 06:13 AM
Last Post: db579
