Bluetooth Debian Testing
(01-20-2020, 05:59 AM)xmixahlx Wrote: placing these here for later:
https://gitlab.manjaro.org/manjaro-arm/p...6-firmware
https://gitlab.manjaro.org/manjaro-arm/p...st-install
I can confirm using those firmware allowed me to have a working bluetooth on Debian testing.
Thank you for the pointers.
Do you mind to post the steps you did in order to have this working? (having those steps in the wiki ti would be even better Big Grin https://wiki.pine64.org/index.php/Pinebo..._Installer)
My bluetoothctl complains about 'No default controller available'
Thanks.
Thanks.
Done Smile It works fine if you just copy https://gitlab.manjaro.org/manjaro-arm/p...6-firmware to /lib/firmware/brcm/.
PBP ISO / Debian Bullseye (unofficial installer)
yes, sorry, correct. just copy all files from the manjaro firmware git to /lib/firmware/brcm/. apparently one or more of the other firmware files are needed.
I have been working on debian sid and can confirm this works their too.
this will be added to the installer, so it will be just a trivial history soon...
With a bit of trouble, have done this, works with bt keyboard, curiously icon vanishes (in dock, it is still there, just invisible)
You have to specifically tell it to connect, why would one bother to pair and type (quickly vanishing) verification key
and not want to connect???
No one here is (coyly) saying whether they followed the PKGBUILD instructions, renaming and all. ....I did
Also copied the hciattach from other package, but not the systemd stuff, too different
Thought I had broke it, wifi dropped, refused to reconnect, this logon slow to connect, 3 tries? but is working
And, just testing again, typed with bt keyboard, this line
to be clear, you can just copy the firmware files as is to /lib/firmware/brcm/ and it will work.
  Debian on Pinebook Pro u974615 7 1,222 03-31-2024, 10:11 AM
Last Post: u974615
  install debian on pbp jsch 7 4,135 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,590 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,127 07-15-2023, 02:58 PM
Last Post: u974615
  Big bluetooth problems ColoBill 2 1,168 12-15-2022, 01:38 PM
Last Post: ColoBill
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,294 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,366 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,068 10-19-2022, 03:09 AM
Last Post: alpopa
  Testing a broken Vulkan driver LivingLinux 0 908 09-26-2022, 05:08 AM
Last Post: LivingLinux
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 1,932 09-23-2022, 08:37 PM
Last Post: computerc
