gcc-aarch64-linux-gnu on Debian armhf?
A little bit novice here and sry if it has already been discussed.
The preinstalled is is Debian for armhf and have therefor not full support for arm64?
I'm missing the 64 bit arm cross-compiler gcc-aarch64-linux-gnu
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 crossbuild-essential-arm64 : Depends: gcc-aarch64-linux-gnu (>= 5.3) but it is not installable
                              Depends: g++-aarch64-linux-gnu (>= 5.3) but it is not installable
E: Unable to correct problems, you have held broken packages.
Again, novice here and could have fucked up things. The dpkg --print-architecture says i have armhf.
Maybe this is answered somewhere here
But ...
armhf or armv7-hardfloat
and
aarch64
are different targets.
You can't mix them.
If you want to use them both on your pinebook you have to chroot in each target rootfs
Also it is not possible (currently) to use both targets in *one* rootfs.
And if you do this via chroot, you'll (maybe) get problems with some hardware i.e. graphics.
multiarch is here the "keyword"
There is some work to be done, to support multiarch, i.e. aarch64 and armv7 in one binary.
But currently this is not the case.
But don't worry your progs get ~3GB max. RAM each and the binaries are (maybe) smaller
  Debian on Pinebook Pro u974615 7 1,039 03-31-2024, 10:11 AM
Last Post: u974615
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 346 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  install debian on pbp jsch 7 4,050 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,439 09-07-2023, 09:38 PM
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,487 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,066 07-15-2023, 02:58 PM
Last Post: u974615
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 664 07-13-2023, 05:21 PM
Last Post: owaspfap
  Kali Linux for Pinebook Pro Luke 100 159,876 05-03-2023, 06:10 AM
Last Post: dachalife
  slarm64 (unofficial slackware) Pinebook Pro RK3399 (aarch64) mara 41 38,877 03-18-2023, 04:39 AM
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,279 12-09-2022, 12:43 PM
Last Post: as365n4
