#81
(11-25-2019, 05:48 AM)Feakster Wrote: Manjaro Preview 4 is out now:
Fully working bluetooth
Fixed Wifi instability
Did, the pacman upgrade. Bluetooth works for me, but Wifi crashed twice, each time I managed to get it back by power-cycling with the privacy switch and then doing the unbind/bind trick.
#82
Can I use Nightlight in sway? What is the name of the package or does it come with KDE/GNome Shell? That would be overkill to install.
#83
(11-26-2019, 07:17 AM)lispy Wrote: Can I use Nightlight in sway? What is the name of the package or does it come with KDE/GNome Shell? That would be overkill to install.
I think it's part of Wayland, looks like it might be available as part of Sway. Yup, it's mentioned on their wiki.
#84
Using KDE moved from XFCE I have not yet made my mind. I likely will reinstall when out of preview. Using now a bluetooth mouse .... it feels good Smile
Wifi has been stable too and the touchpad without click for left click has been nice to have, I had to reinstall preview3, and update from preview2 was not enough.
#85
Please disable 'sdio-hciattach'
sudo systemctl disable sdio-hciattach
This should help with wifi. If not please report back
Thank you.
Manjaro ARM Team.
#86
I really like how dim the screen can get with KDE and that it can turn off the backlight completely.
Perfect to get the last ounce of battery life from the device Big Grin
#87
(11-26-2019, 01:02 PM)spikerguy Wrote: Please disable 'sdio-hciattach'
I don't even have a sido-hciattach.service.
Seem that the trouble are firmware-related: I followed tsys' advice and fetched the latest firmware from gitlab and haven't seen a crash yet.
#88
Thanks to @"Feakster" (I hope it's the same user Smile ) for pointing out that USB-C video out is working now on the Manjaro forum!
So, from the basics I'm only missing separate headphone and speakers output now Smile
#89
(12-04-2019, 05:01 AM)PakoSt Wrote: Thanks to @"Feakster"  (I hope it's the same user Smile ) for pointing out that USB-C video out is working now on the Manjaro forum!
Tis indeed.
#90
i just get a mirror image no extended monitor
  Official Debian support moonwalkers 63 53,522 05-16-2024, 11:00 PM
Last Post: rempfer
  Debian on Pinebook Pro u974615 7 1,549 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 406 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 2,074 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,849 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 458 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,332 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,461 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 91,016 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 516 12-07-2023, 03:11 PM
