(03-16-2020, 02:41 PM)dhosh Wrote: 5.6.0-0.4-MANJARO-ARM
LibreOffice:
Version: 6.4.1.2
Build ID: 6.4.1-3
CPU threads: 6; OS: Linux 5.6; UI render: default; VCL: kf5;
Locale: en-US (en_US.utf8); UI-Language: en-US
Calc: threaded
When working with documents in Writer, I get random pastes of what appears to be in my clipboard.  I likely pasted the text once, but it shows up in multiple random locations in the document.  I can go through and clean them up (delete them), and I swear they pop up elsewhere!  I can go to Manjaro's clipboard and clear it, and they still seem to creep in.
I have found a similar post regarding LibreOffice, and they pointed to hardware, or OS issues.
Anyone else see these issues?  I have not noticed this happening in any other application, but then again, I don't write a lot of text in any other application.
I will try to replicate this situation and then report back.
Manjaro ARM Team.
I've cloned my live SD card (on which I'd installed Manjaro) to the eMMC using dd. It worked like a charm at first try, but digging deeper, I've realized this was a risky move, that I should have used cat or something else. So please, don't do what I did, unless you want to.
Creating is Everything
Away
oh... that is what the emmc installer is for...
your sdcard clone is probably broken, you just aren't yet aware.
(03-23-2020, 07:29 PM)8jef Wrote: I've cloned my live SD card (on which I'd installed Manjaro) to the eMMC using dd. It worked like a charm at first try, but digging deeper, I've realized this was a risky move, that I should have used cat or something else. So please, don't do what I did, unless you want to.
Pretty sure dd is the way to go, this is how I copied Manjaro from the SD card to eMMC, too and it is working.
There are a number of directories that should NOT be copied,
they are empty until booted,,, dev, sys, proc, run
The directory should exist, empty
dd copies it and contents, and then it is not empty
rsync is the way, specific directories (all but above)
I should be more clear, I copied the disk device directly, not a mounted system. Computer was booted off an SD card, the Manjaro that was working for me was in an SD card reader in the USB slot, then I copied it from the USB to the eMMC with dd and it works.
How frequently should my install be getting updates?  I've been using the updater through KDE discover and haven't had any for a while now.
(04-13-2020, 09:56 PM)inspiredrat Wrote: How frequently should my install be getting updates?  I've been using the updater through KDE discover and haven't had any for a while now.
You may need to switch to the new mirror list: https://forum.manjaro.org/t/another-mirr...red/132302
I just followed the instructions on the thread and now my Pinebook Pro will not boot.  It seemed as if the updates ran correctly from the terminal.  When I tried to reboot the only thing I get is a red light.  Can you please let me know what next steps might be in troubleshooting?
Ah sounds like this issue: https://forum.manjaro.org/t/arm-stable-u...s/133266/2
  Debian on Pinebook Pro u974615 7 1,072 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 295 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,628 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,767 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 347 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,166 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,239 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,156 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 418 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,266 11-23-2023, 07:37 AM
Users browsing this thread: 8 Guest(s)
