hardware-accelerated video transcoding (Plex) on Rock64
Hi everybody,
I have a Rock64 board which had been lying around for a while, but I now seriously want to deploy as a NAS/Media server replacement for my ageing Synology DS414. Therefore my entry on the forums here Smile
My goal is to run OpenMediaVault as NAS solution. On top of that run Plex Media Server and possibly a few docker containers. I've been testing several images to see which works best for me:
- ayufan's OMV image, with Plex as plugin (or docker)
- Armbian Stretch with Plex installed via Softy
- for testing purposes: another x86 machine with own OMV installation and Plex in docker, but that's beyond the scope of this forum
OMV works perfectly on the NAS with ayufan's build, but the issue is with Plex video transcoding, Obviously the ARM CPU isn't suitable for that but I understood that the Rockchip RK3328 should have hardware encoding/decoding/transcoding capabilities. Plex supports it on Ubuntu, but OMV requires Debian. Since one is based on the other I'm hoping that can be made working.
But before I spend an inordinate amount tyring to get this working (and I'm not a sysadmin): has anybody got hardware accelerated video to work already on Rock64/Linux? I've searched the forum but couldn't find a recent answer to this.
If it works, some pointers how this is done would be MUCH appreciated. If doesn't work, that answer is also helpful because it would save me a lot of time. Thanks in advance!
(02-07-2019, 10:45 AM)mdr Wrote: OMV works perfectly on the NAS with ayufan's build, but the issue is with Plex video transcoding, Obviously the ARM CPU isn't suitable for that but I understood that the Rockchip RK3328 should have hardware encoding/decoding/transcoding capabilities.
While there is hardware encoding, it hasn't been ported from android.
Thanks for the answer, helpful either way. I'd heard this would be tricky but it was worth a try.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,374 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 621 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 615 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,440 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,809 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 594 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  How to Change Video Memory Amount gazhow64 0 734 12-10-2022, 04:12 PM
Last Post: gazhow64
