hardware-accelerated video transcoding (Plex) on Rock64
Hi everybody,
I have a Rock64 board which had been lying around for a while, but I now seriously want to deploy as a NAS/Media server replacement for my ageing Synology DS414. Therefore my entry on the forums here Smile
My goal is to run OpenMediaVault as NAS solution. On top of that run Plex Media Server and possibly a few docker containers. I've been testing several images to see which works best for me:
- ayufan's OMV image, with Plex as plugin (or docker)
- Armbian Stretch with Plex installed via Softy
- for testing purposes: another x86 machine with own OMV installation and Plex in docker, but that's beyond the scope of this forum
OMV works perfectly on the NAS with ayufan's build, but the issue is with Plex video transcoding, Obviously the ARM CPU isn't suitable for that but I understood that the Rockchip RK3328 should have hardware encoding/decoding/transcoding capabilities. Plex supports it on Ubuntu, but OMV requires Debian. Since one is based on the other I'm hoping that can be made working.
But before I spend an inordinate amount tyring to get this working (and I'm not a sysadmin): has anybody got hardware accelerated video to work already on Rock64/Linux? I've searched the forum but couldn't find a recent answer to this.
If it works, some pointers how this is done would be MUCH appreciated. If doesn't work, that answer is also helpful because it would save me a lot of time. Thanks in advance!
(02-07-2019, 10:45 AM)mdr Wrote: OMV works perfectly on the NAS with ayufan's build, but the issue is with Plex video transcoding, Obviously the ARM CPU isn't suitable for that but I understood that the Rockchip RK3328 should have hardware encoding/decoding/transcoding capabilities.
While there is hardware encoding, it hasn't been ported from android.
Thanks for the answer, helpful either way. I'd heard this would be tricky but it was worth a try.
  Xen hypervisor on Rock64 tumbleweed 6 9,803 11-03-2025, 09:25 AM
Last Post: darkfader
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 9 15,821 07-20-2025, 01:00 PM
  Rock64 - not booting after Armbian update helpmerock 6 3,695 03-27-2025, 08:26 AM
  can rock64 4gb ram run entirely on free software? heocb 1 2,383 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,500 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 3,541 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 68,942 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 100,381 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 4,467 03-14-2024, 03:09 AM
  Rock64 won't boot dstallmo 0 2,623 12-27-2023, 10:34 AM
Last Post: dstallmo
