Rock64 0.6.x ayufan images
#21
How to update from 0.65 to new
0.66 image
rock64@rock64:~$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
rock64@rock64:~$ sudo apt-get dist-upgrade
rock64@rock64:~$ sudo apt-get install linux-rock64
linux-rock64 is already the newest version (0.6.5).
there is an update file along with the image files on ayufans git
(01-02-2018, 09:46 AM)dkryder Wrote: there is an update file along with the image files on ayufans git
Great but what is this called as there are many under https://github.com/ayufan-rock64/linux-build/releases
& what command do I use to update.
6.6.6 is removed
you can try 6.6.7 or 6.6.8
When Dist-update from bionic-minimal-rock64-0.6.9-160-arm64.img.xz to 0.6.10  get this error.
Quote:Setting up linux-rock64-package (0.6.10) ...
e2label: Filesystem has unsupported read-only feature(s) while trying to open /dev/mmcblk1p7
Couldn't find valid filesystem superblock.
dpkg: error processing package linux-rock64-package (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of linux-rock64:
 linux-rock64 depends on linux-rock64-package (= 0.6.10); however:
  Package linux-rock64-package is not configured yet.
dpkg: error processing package linux-rock64 (--configure):
 dependency problems - leaving unconfigured
Processing triggers for flash-kernel (3.75ev3dev5) ...
Using DTB: rk3328-rock64.dtb
Installing /usr/lib/linux-image-4.4.103-rockchip-ayufan-162/rockchip/rk3328-rock64.dtb into /boot/dtbs/4.4.103-rockchip-ayufan-162/rk3328-rock64.dtb
Taking backup of rk3328-rock64.dtb.
Installing new rk3328-rock64.dtb.
flash-kernel: installing version 4.4.103-rockchip-ayufan-162
Taking backup of Image.
Installing new Image.
Taking backup of initrd.img.
Installing new initrd.img.
Taking backup of dtb.
Installing new dtb.
Errors were encountered while processing:
 linux-rock64
E: Sub-process /usr/bin/dpkg returned an error code (1)
Whats Wrong?
And can this be fixed?
just as an aside, ayufan has said a couple times in the forum that he would prefer opening issues on the github repo since it helps him track issues. another thing i do not think you fully understand yet is these pre-releases are basically untested, non-perfect, first release very alpha type builds. so to show up with what seems like demands for info, instead of reporting the issue in the proper place as more of a fyi to the developer, rather than questions about what the errors are and when or if a fix is coming, might place you as a better community member willing to test, report and help. usually stuff gets fixed when it can and will be ready when it is. if you can not accept that you would be better off just using the latest release rather than these bleeding edge builds.
https://etcher.io/   go there lmk what u guys think I was linked to this page guys from the rock 64 forms and evidently you can use windows you can use linux on the rock 64 is this true can anybody validate this and if so could you email me back pretty please this is important to me to find this out it's upsetting that there is not a lot of youtube videos about the rock 64 I wish there was a bigger family.  Lol.   Vaper4103@gmail.com.  pleezz help me
(11-28-2017, 05:24 AM)matteobp Wrote: Hi al
I'm wondering if you guys? If any jumpers have to be set or placed in place first before booting directly from the micro SD card. Could you please email me on this subject
Question regarding update 0.6.16. How will the change' Limit USB3 to HS mode in u-boot' affect USB performance? Why was this changed? Question for ayufan I guess... Thanks.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,374 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 621 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 614 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,436 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,791 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 594 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,474 12-07-2022, 08:22 PM
Last Post: luminosity7
