Rock64 0.6.x ayufan images
Hi all.
I have a Rock64 board with 1GB, no EMMC module.
I was able to try the 0.5.10 images, like "xenial-mate" and "stretch-minimal" (with the XFCE4 desktop environment installed later), but if I try the 0.6.x images, when I power the board, all 3 leds light up and remains on, nothing else happens.
I tried both Etcher and dd command method to write the SD card (Samsung EVO 16GB).
I can exclude problems with power supply (I bought the one they suggested on their site, 5V 3A) and with SD card because I have no problem with 0.5.10 images.
Is something missing?
Thanks in advance
Matteo
https://github.com/ayufan-rock64/linux-build/releases
Notes
"Make SPL/TPL actually to work"
So try that.
(11-29-2017, 05:15 AM)elatllat Wrote: 0.6.1
Notes
So try that.
How can I do this? I suppose the image is ready to flash. I tried to search on google, but I didn't find anything useful for the image writing.
Can you help me?
Thanks in advance
Matteo
Got the same Probleme... Angry
Probably there are different productions, and some of us have different board from other. I'm not even able to use the "armbian" distribution (downloaded here: https://www.armbian.com/rock64/)
while other users can use it without problem.
Are there different productions? Is there a check about the "production"?
Matteo
is there an easy way to to update from 0.5.1xx to 0.6.1xx ?
Have you already tried ... ?
sudo apt-get install linux-rock64 -y
I am not sure if it updates from one 0.X version to another however.
Reading package lists... Done
Building dependency tree
Reading state information... Done
linux-rock64 is already the newest version (0.5.15).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
So we stay on 0.5.1x Version
(12-07-2017, 08:57 AM)Rar9 Wrote: sudo apt-get install linux-rock64 -y
Ah yes. Well, you may need to ask ayufan directly about this - best chance is IRC
I go from [microSD to eMMC] [0.5.10-118] to 0.6.x version without problem.
IIRC I do :
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,373 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 619 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 613 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,424 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,744 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 593 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,464 12-07-2022, 08:22 PM
Last Post: luminosity7
