Lakka test boot-up Rock64.arm-8.1.2 dmesg logfile
Information
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.83 (demetris@Server01) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP Fri Sep 29 10:33:18 CDT 2017
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] On node 0 totalpages: 1043968
[    0.000000]   DMA zone: 16312 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 1043968 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0fef38000 s45864 r8192 d31960 u86016
[    0.000000] pcpu-alloc: s45864 r8192 d31960 u86016 alloc=21*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1027656
[    0.000000] Kernel command line: root=/dev/ram0 rdinit=/init BOOT_IMAGE=/Image usbcore.autosuspend=-1 earlyprintk console=ttyFIQ0 console=tty0 boot=UUID=2909-2628 disk=UUID=11c779c3-8cfd-4e31-943e-58321082a130 textmode ssh
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB [mem 0xf6400000-0xfa400000] (64MB) mapped at [ffffffc0f6400000-ffffffc0fa3fffff]
[    0.000000] Memory: 4020164K/4175872K available (8894K kernel code, 1296K rwdata, 3416K rodata, 2880K init, 648K bss, 155708K reserved, 0K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
[    0.000000]       .init : 0xffffff8008c90000 - 0xffffff8008f60000   (  2880 KB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008930000   (  8896 KB)
[    0.000000]     .rodata : 0xffffff8008930000 - 0xffffff8008c90000   (  3456 KB)
[    0.000000]       .data : 0xffffff8008f60000 - 0xffffff80090a4008   (  1297 KB)
[    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
[    0.000000]               0xffffffbdc0008000 - 0xffffffbdc3fc0000   (    63 MB actual)
[    0.000000]     fixed   : 0xffffffbffe7fd000 - 0xffffffbffec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
[    0.000000]     memory  : 0xffffffc000200000 - 0xffffffc0ff000000   (  4078 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]     Build-time adjustment of leaf fanout to 64.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000832] Console: colour dummy device 80x25
[    0.002166] console [tty0] enabled
[    0.002214] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.002284] pid_max: default: 32768 minimum: 301
[    0.002472] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.002519] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.003499] Initializing cgroup subsys io
[    0.003549] Initializing cgroup subsys memory
[    0.003611] Initializing cgroup subsys devices
[    0.003655] Initializing cgroup subsys freezer
[    0.003697] Initializing cgroup subsys pids
[    0.003755] ftrace: allocating 34156 entries in 134 pages
[    0.092162] sched-energy: CPU device node has no sched-energy-costs
[    0.092216] Invalid sched_group_energy for CPU0
[    0.092250] CPU0: update cpu_capacity 1024
[    0.092340] ASID allocator initialised with 65536 entries
[    0.097199] Detected VIPT I-cache on CPU1
[    0.097258] Invalid sched_group_energy for CPU1
[    0.097264] CPU1: update cpu_capacity 1024
[    0.097269] CPU1: Booted secondary processor [410fd034]
[    0.097925] Detected VIPT I-cache on CPU2
[    0.097972] Invalid sched_group_energy for CPU2
[    0.097978] CPU2: update cpu_capacity 1024
[    0.097983] CPU2: Booted secondary processor [410fd034]
[    0.098667] Detected VIPT I-cache on CPU3
[    0.098711] Invalid sched_group_energy for CPU3
[    0.098716] CPU3: update cpu_capacity 1024
[    0.098721] CPU3: Booted secondary processor [410fd034]
[    0.098822] Brought up 4 CPUs
[    0.099197] SMP: Total of 4 processors activated.
[    0.099239] CPU: All CPU(s) started at EL2
[    0.099303] alternatives: patching kernel code
[    0.099537] Invalid sched_group_energy for CPU3
[    0.099574] Invalid sched_group_energy for Cluster3
[    0.099608] Invalid sched_group_energy for CPU2
[    0.099642] Invalid sched_group_energy for Cluster2
[    0.099676] Invalid sched_group_energy for CPU1
[    0.099710] Invalid sched_group_energy for Cluster1
[    0.099743] Invalid sched_group_energy for CPU0
[    0.099777] Invalid sched_group_energy for Cluster0
[    0.100531] devtmpfs: initialized
[    0.116323] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.116415] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.116993] pinctrl core: initialized pinctrl subsystem
[    0.117377] regulator-dummy: no parameters
[    0.118261] NET: Registered protocol family 16
[    0.132123] cpuidle: using governor ladder
[    0.145482] cpuidle: using governor menu
[    0.145536] Registered FIQ tty driver
[    0.146038] vdso: 2 pages (1 code @ ffffff8008936000, 1 data @ ffffff8008f64000)
[    0.146131] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.146315] DMA: preallocated 256 KiB pool for atomic allocations
[    0.159508] gpiochip_add: registered GPIOs 1000 to 1031 on device: gpio0
[    0.159648] gpiochip_add: registered GPIOs 1032 to 1063 on device: gpio1
[    0.159775] gpiochip_add: registered GPIOs 1064 to 1095 on device: gpio2
[    0.159910] gpiochip_add: registered GPIOs 1096 to 1127 on device: gpio3
[    0.169031] genirq: Setting trigger mode 8 for irq 176 failed (gic_set_type+0x0/0x64)
[    0.219554] console [ttyFIQ0] enabled
[    0.220215] Registered fiq debugger ttyFIQ0
[    0.234193] mpp venc_srv: mpp_probe enter
[    0.234651] mpp venc_srv: init success
[    0.235647] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    0.235683] vcc_phy: no parameters
[    0.235916] reg-fixed-voltage vcc-phy-regulator: vcc_phy supplying 0uV
[    0.236184] of_get_named_gpiod_flags: parsed 'gpio' property of node '/sdmmc-regulator[0]' - status (0)
[    0.236249] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree
[    0.236271] vcc_sd: unable to resolve supply
[    0.236286] vcc_sd: 3300 mV
[    0.236505] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree
[    0.236526] vcc_sd: unable to resolve supply
[    0.236544] reg-fixed-voltage sdmmc-regulator: vcc_sd supplying 3300000uV
[    0.236627] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-sys[0]'
[    0.236655] vcc_sys: 5000 mV
[    0.236856] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree
[    0.236877] vcc_sd: unable to resolve supply
[    0.236895] reg-fixed-voltage vcc-sys: vcc_sys supplying 5000000uV
[    0.237488] iommu: Adding device ff350000.vpu-service to group 0
[    0.238180] iommu: Adding device ff360000.rkvdec to group 1
[    0.238773] iommu: Adding device ff330000.h265e to group 2
[    0.239372] iommu: Adding device ff340000.vepu to group 3
[    0.239956] iommu: Adding device ff370000.vop to group 4
[    0.241574] rk_iommu ff330200.iommu: can't get aclk
[    0.242055] rk_iommu ff330200.iommu: can't get hclk
[    0.243508] SCSI subsystem initialized
[    0.244169] usbcore: registered new interface driver usbfs
[    0.244762] usbcore: registered new interface driver hub
[    0.245394] usbcore: registered new device driver usb
[    0.246064] Linux cec interface: v0.10
[    0.246511] pps_core: LinuxPPS API ver. 1 registered
[    0.246987] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.247865] PTP clock support registered
[    0.249912] Advanced Linux Sound Architecture Driver Initialized.
[    0.251263] Bluetooth: Core ver 2.21
[    0.251652] NET: Registered protocol family 31
[    0.252111] Bluetooth: HCI device and connection manager initialized
[    0.252710] Bluetooth: HCI socket layer initialized
[    0.253179] Bluetooth: L2CAP socket layer initialized
[    0.253683] Bluetooth: SCO socket layer initialized
[    0.254563] cfg80211: World regulatory domain updated:
[    0.255050] cfg80211:  DFS Master region: unset
[    0.255471] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    0.256404] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    0.257161] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    0.258038] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    0.258793] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    0.259698] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    0.260588] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[    0.261352] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    0.262105] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[    0.263360] rockchip-cpuinfo cpuinfo: Serial        : bbc99184ba566da9
[    0.264822] clocksource: Switched to clocksource arch_sys_counter
[    0.337887] FS-Cache: Loaded
[    0.352060] NET: Registered protocol family 2
[    0.353133] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.354287] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[    0.356449] TCP: Hash tables configured (established 32768 bind 32768)
[    0.357172] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[    0.357997] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[    0.359188] NET: Registered protocol family 1
[    0.360076] RPC: Registered named UNIX socket transport module.
[    0.360637] RPC: Registered udp transport module.
[    0.361087] RPC: Registered tcp transport module.
[    0.361580] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.362253] PCI: CLS 0 bytes, default 64
[    0.495750] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.514780] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.516530] FS-Cache: Netfs 'nfs' registered for caching
[    0.517711] NFS: Registering the id_resolver key type
[    0.518258] Key type id_resolver registered
[    0.518664] Key type id_legacy registered
[    0.519073] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.520027] FS-Cache: Netfs 'cifs' registered for caching
[    0.527387] NET: Registered protocol family 38
[    0.527866] Key type asymmetric registered
[    0.528297] Asymmetric key parser 'x509' registered
[    0.529060] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.529987] io scheduler noop registered
[    0.530386] io scheduler deadline registered
[    0.530848] io scheduler cfq registered (default)
[    0.532638] phy phy-ff450000.syscon:usb2-phy@100.0: Looking up phy-supply from device tree
[    0.532662] phy phy-ff450000.syscon:usb2-phy@100.0: Looking up phy-supply property in node /syscon@ff450000/usb2-phy@100/host-port failed
[    0.533106] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up phy-supply from device tree
[    0.533127] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up phy-supply property in node /syscon@ff450000/usb2-phy@100/otg-port failed
[    0.533472] rockchip-usb2phy ff450000.syscon:usb2-phy@100: GPIO lookup for consumer otg-vbus
[    0.533489] rockchip-usb2phy ff450000.syscon:usb2-phy@100: using device tree for GPIO lookup
[    0.533528] of_get_named_gpiod_flags: parsed 'otg-vbus-gpios' property of node '/syscon@ff450000/usb2-phy@100[0]' - status (0)
[    0.534224] rockchip-u3phy ff470000.usb3-phy: GPIO lookup for consumer vbus-drv
[    0.534242] rockchip-u3phy ff470000.usb3-phy: using device tree for GPIO lookup
[    0.534275] of_get_named_gpiod_flags: parsed 'vbus-drv-gpios' property of node '/usb3-phy@ff470000[0]' - status (0)
[    0.534678] phy phy-ff470000.usb3-phy.2: Looking up phy-supply from device tree
[    0.534698] phy phy-ff470000.usb3-phy.2: Looking up phy-supply property in node /usb3-phy@ff470000/utmi@ff470000 failed
[    0.535133] phy phy-ff470000.usb3-phy.3: Looking up phy-supply from device tree
[    0.535153] phy phy-ff470000.usb3-phy.3: Looking up phy-supply property in node /usb3-phy@ff470000/pipe@ff478000 failed
[    0.537505] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully
[    0.538755] phy phy-ff430000.hdmiphy.4: Looking up phy-supply from device tree
[    0.538776] phy phy-ff430000.hdmiphy.4: Looking up phy-supply property in node /hdmiphy@ff430000 failed
[    0.541518] rk-vcodec ff350000.vpu-service: probe device
[    0.542063] rk-vcodec ff350000.vpu-service: vpu mmu dec ffffffc0f5dea010
[    0.542965] rk-vcodec ff350000.vpu-service: allocator is drm
[    0.543579] rk-vcodec ff350000.vpu-service: checking hw id 0
[    0.544654] rk-vcodec ff350000.vpu-service: init success
[    0.545997] rk-vcodec ff360000.rkvdec: probe device
[    0.546504] rk-vcodec ff360000.rkvdec: vpu mmu dec ffffffc0f5dea810
[    0.547357] rk-vcodec ff360000.rkvdec: allocator is drm
[    0.547930] rk-vcodec ff360000.rkvdec: checking hw id 3410
[    0.549023] rk-vcodec ff360000.rkvdec: init success
[    0.549970] probe device ff330000.h265e
[    0.550663] mpp_dev ff330000.h265e: try to get iommu dev ffffffc0f5deb010
[    0.551738] mpp_dev ff330000.h265e: resource ready, register device
[    0.552651] probe device ff340000.vepu
[    0.553316] mpp_dev ff340000.vepu: try to get iommu dev ffffffc0f5deb810
[    0.554238] rockchip_mpp_vepu_reset_init:143: No aclk reset resource define
[    0.554926] rockchip_mpp_vepu_reset_init:148: No hclk reset resource define
[    0.555576] mpp_dev ff340000.vepu: resource ready, register device
[    0.559193] dma-pl330 ff1f0000.dmac: Loaded driver for PL330 DMAC-241330
[    0.559833] dma-pl330 ff1f0000.dmac:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    0.561601] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.564705] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[    0.568449] rockchip-vop ff370000.vop: failed to get vop register byname
[    0.569120] rockchip-vop ff370000.vop: invalid resource
[    0.569621] rockchip-vop ff370000.vop: failed to get vop lut registers
[    0.570234] rockchip-vop ff370000.vop: invalid resource
[    0.570733] rockchip-vop ff370000.vop: failed to get vop cabc lut registers
[    0.571651] rockchip-drm display-subsystem: bound ff370000.vop (ops 0xffffff80089bfb08)
[    0.572770] i2c i2c-4: of_i2c: modalias failure on /hdmi@ff3c0000/ports
[    0.573395] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
[    0.574206] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
[    0.576154] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops 0xffffff80089ba418)
[    0.576937] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    0.577691] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[    0.578556] rockchip-drm display-subsystem: failed to parse display resources
[    1.231606] Console: switching to colour frame buffer device 160x45
[    1.254472] rockchip-drm display-subsystem: fb0:  frame buffer device
[    1.259237] Registered IR keymap rc-cec
[    1.260318] input: RC for dw_hdmi as /devices/platform/ff3c0000.hdmi/rc/rc0/input0
[    1.261287] rc0: RC for dw_hdmi as /devices/platform/ff3c0000.hdmi/rc/rc0
[    1.262661] Unable to detect cache hierarchy from DT for CPU 0
[    1.264580] brd: module loaded
[    1.273524] loop: module loaded
[    1.275028] zram: Added device: zram0
[    1.275847] lkdtm: No crash points registered, enable through debugfs
[    1.276893] Loading iSCSI transport class v2.0-870.
[    1.277978] iscsi: registered transport (tcp)
[    1.280018] rockchip-spi ff190000.spi: Failed to request TX DMA channel
[    1.280879] rockchip-spi ff190000.spi: Failed to request RX DMA channel
[    1.282647] m25p80 spi32766.0: gd25q128 (16384 Kbytes)
[    1.283362] 6 ofpart partitions found on MTD device spi32766.0
[    1.284098] Creating 6 MTD partitions on "spi32766.0":
[    1.284756] 0x000000000000-0x000000008000 : "system"
[    1.285914] 0x000000008000-0x000000400000 : "loader"
[    1.286982] 0x000000400000-0x0000007c0000 : "reserved"
[    1.288057] 0x0000007c0000-0x000000800000 : "vendor"
[    1.297192] 0x000000800000-0x000000c00000 : "uboot"
[    1.306211] 0x000000c00000-0x000001000000 : "atf"
[    1.316664] rk_gmac-dwmac ff540000.ethernet: Looking up phy-supply from device tree
[    1.316788] rk_gmac-dwmac ff540000.ethernet: clock input or output? (input).
[    1.325494] rk_gmac-dwmac ff540000.ethernet: TX delay(0x26).
[    1.333886] rk_gmac-dwmac ff540000.ethernet: RX delay(0x11).
[    1.342114] rk_gmac-dwmac ff540000.ethernet: integrated PHY? (no).
[    1.350567] rk_gmac-dwmac ff540000.ethernet: clock input from PHY
[    1.363789] rk_gmac-dwmac ff540000.ethernet: init for RGMII
[    1.371985] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    1.380069]  Ring mode enabled
[    1.387862]  DMA HW capability register supported
[    1.388460]  Normal descriptors
[    1.403380]  RX Checksum Offload Engine supported (type 2)
[    1.411206]  TX Checksum insertion supported
[    1.418765]  Wake-Up On Lan supported
[    1.426262]  Enable RX Mitigation via HW Watchdog Timer
[    1.433950] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@ff540000[0]' - status (0)
[    1.506985] libphy: stmmac: probed
[    1.514193] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active
[    1.521650] eth%d: PHY ID 001cc916 at 1 IRQ POLL (stmmac-0:01)
[    1.530074] usbcore: registered new interface driver rndis_wlan
[    1.537494] Rockchip WiFi SYS interface (V1.00) ...
[    1.544636] usbcore: registered new interface driver rtl8150
[    1.551698] usbcore: registered new interface driver r8152
[    1.558564] usbcore: registered new interface driver asix
[    1.565228] usbcore: registered new interface driver ax88179_178a
[    1.571817] usbcore: registered new interface driver cdc_ether
[    1.578262] usbcore: registered new interface driver rndis_host
[    1.584562] usbcore: registered new interface driver cdc_ncm
[    1.590614] usbcore: registered new interface driver cdc_mbim
[    1.598327] phy phy-ff470000.usb3-phy.2: u3phy u2 power on
[    1.604228] phy phy-ff470000.usb3-phy.3: u3phy u3 power on
[    1.611002] dwc2 ff580000.usb: Looking up vusb_d-supply from device tree
[    1.611024] dwc2 ff580000.usb: Looking up vusb_d-supply property in node /usb@ff580000 failed
[    1.611042] ff580000.usb supply vusb_d not found, using dummy regulator
[    1.617146] dwc2 ff580000.usb: Looking up vusb_a-supply from device tree
[    1.617167] dwc2 ff580000.usb: Looking up vusb_a-supply property in node /usb@ff580000 failed
[    1.617183] ff580000.usb supply vusb_a not found, using dummy regulator
[    1.851734] dwc2 ff580000.usb: DWC OTG Controller
[    1.857430] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
[    1.863408] dwc2 ff580000.usb: irq 40, io mem 0x00000000
[    1.869370] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.875408] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.881451] usb usb1: Product: DWC OTG Controller
[    1.887196] usb usb1: Manufacturer: Linux 4.4.83 dwc2_hsotg
[    1.893021] usb usb1: SerialNumber: ff580000.usb
[    1.899561] hub 1-0:1.0: USB hub found
[    1.905278] hub 1-0:1.0: 1 port detected
[    1.912329] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.918553] ehci-pci: EHCI PCI platform driver
[    1.924644] ehci-platform: EHCI generic platform driver
[    1.933406] ehci-platform ff5c0000.usb: EHCI Host Controller
[    1.939877] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 2
[    1.946502] ehci-platform ff5c0000.usb: irq 41, io mem 0xff5c0000
[    1.961529] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
[    1.968209] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.974786] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.981487] usb usb2: Product: EHCI Host Controller
[    1.987909] usb usb2: Manufacturer: Linux 4.4.83 ehci_hcd
[    1.994379] usb usb2: SerialNumber: ff5c0000.usb
[    2.001600] hub 2-0:1.0: USB hub found
[    2.007942] hub 2-0:1.0: 1 port detected
[    2.014875] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.021467] ohci-platform: OHCI generic platform driver
[    2.028469] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
[    2.035445] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3
[    2.042394] ohci-platform ff5d0000.usb: irq 42, io mem 0xff5d0000
[    2.105762] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    2.112597] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.119408] usb usb3: Product: Generic Platform OHCI controller
[    2.126090] usb usb3: Manufacturer: Linux 4.4.83 ohci_hcd
[    2.132684] usb usb3: SerialNumber: ff5d0000.usb
[    2.140079] hub 3-0:1.0: USB hub found
[    2.146739] hub 3-0:1.0: 1 port detected
[    2.154515] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    2.161823] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 4
[    2.169329] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00210010
[    2.176933] xhci-hcd xhci-hcd.9.auto: irq 180, io mem 0xff600000
[    2.184506] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    2.191977] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.199627] usb usb4: Product: xHCI Host Controller
[    2.206993] usb usb4: Manufacturer: Linux 4.4.83 xhci-hcd
[    2.207002] usb usb4: SerialNumber: xhci-hcd.9.auto
[    2.207847] hub 4-0:1.0: USB hub found
[    2.207894] hub 4-0:1.0: 1 port detected
[    2.208412] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    2.208682] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
[    2.208792] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.208970] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003
[    2.208981] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.208990] usb usb5: Product: xHCI Host Controller
[    2.208998] usb usb5: Manufacturer: Linux 4.4.83 xhci-hcd
[    2.209006] usb usb5: SerialNumber: xhci-hcd.9.auto
[    2.209795] hub 5-0:1.0: USB hub found
[    2.209838] hub 5-0:1.0: 1 port detected
[    2.210534] usbcore: registered new interface driver cdc_acm
[    2.210539] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.210611] usbcore: registered new interface driver cdc_wdm
[    2.210689] usbcore: registered new interface driver uas
[    2.210925] usbcore: registered new interface driver usb-storage
[    2.211059] usbcore: registered new interface driver usbserial
[    2.211113] usbcore: registered new interface driver usbserial_generic
[    2.211155] usbserial: USB Serial support registered for generic
[    2.211225] usbcore: registered new interface driver cp210x
[    2.211272] usbserial: USB Serial support registered for cp210x
[    2.211404] usbcore: registered new interface driver ftdi_sio
[    2.211446] usbserial: USB Serial support registered for FTDI USB Serial Device
[    2.211926] usbcore: registered new interface driver keyspan
[    2.211973] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    2.212015] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    2.212056] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    2.212098] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    2.212190] usbcore: registered new interface driver option
[    2.212238] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.212782] usbcore: registered new interface driver oti6858
[    2.212824] usbserial: USB Serial support registered for oti6858
[    2.212899] usbcore: registered new interface driver pl2303
[    2.212942] usbserial: USB Serial support registered for pl2303
[    2.213033] usbcore: registered new interface driver qcserial
[    2.213081] usbserial: USB Serial support registered for Qualcomm USB modem
[    2.213200] usbcore: registered new interface driver sierra
[    2.213242] usbserial: USB Serial support registered for Sierra USB modem
[    2.214475] usbcore: registered new interface driver iforce
[    2.214588] usbcore: registered new interface driver xpad
[    2.214840] usbcore: registered new interface driver usbtouchscreen
[    2.215457] i2c /dev entries driver
[    2.218100] rk808 1-0018: Pmic Chip id: 0x8050
[    2.219191] rk808 1-0018: source: on=0x40, off=0x00
[    2.223325] rk808 1-0018: Looking up vcc1-supply from device tree
[    2.223442] DCDC_REG1: supplied by vcc_sys
[    2.223455] vcc_sys: could not add device link regulator.4 err -2
[    2.225331] vdd_logic: 712 <--> 1450 mV at 1150 mV
[    2.225633] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree
[    2.225661] vcc_sd: unable to resolve supply
[    2.225683] rk808 1-0018: Looking up vcc2-supply from device tree
[    2.225764] DCDC_REG2: supplied by vcc_sys
[    2.225775] vcc_sys: could not add device link regulator.5 err -2
[    2.227131] vdd_arm: 712 <--> 1450 mV at 1000 mV
[    2.227398] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree
[    2.227420] vcc_sd: unable to resolve supply
[    2.227441] rk808 1-0018: Looking up vcc3-supply from device tree
[    2.227504] DCDC_REG3: supplied by vcc_sys
[    2.227514] vcc_sys: could not add device link regulator.6 err -2
[    2.228730] vcc_ddr: at 5000 mV
[    2.228953] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree
[    2.228973] vcc_sd: unable to resolve supply
[    2.228995] rk808 1-0018: Looking up vcc4-supply from device tree
[    2.229051] DCDC_REG4: supplied by vcc_sys
[    2.229061] vcc_sys: could not add device link regulator.7 err -2
[    2.229938] vcc_io: 3300 mV
[    2.230230] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree
[    2.230252] vcc_sd: supplied by vcc_io
[    2.230322] rk808 1-0018: Looking up vcc5-supply from device tree
[    2.230339] LDO_REG1: supplied by vcc_io
[    2.230349] vcc_io: could not add device link regulator.8 err -2
[    2.232677] vcc_18: 1800 mV
[    2.232938] rk808 1-0018: Looking up vcc5-supply from device tree
[    2.232957] LDO_REG2: supplied by vcc_io
[    2.232967] vcc_io: could not add device link regulator.9 err -2
[    2.235298] vcc18_emmc: 1800 mV
[    2.235594] rk808 1-0018: Looking up vcc6-supply from device tree
[    2.235691] LDO_REG3: supplied by vcc_sys
[    2.235702] vcc_sys: could not add device link regulator.10 err -2
[    2.238038] vdd_10: 1000 mV
[    2.238338] rk808 1-0018: register rk8050 regulators
[    2.238550] gpiochip_find_base: cannot find free range
[    2.238557] gpiochip_add: GPIOs -1..0 (rk8xx-gpio) failed to register
[    2.238566] rk8xx-gpio rk8xx-gpio: register rk8xx gpiochip fail: -28
[    2.238583] rk8xx-gpio: probe of rk8xx-gpio failed with error -28
[    2.240650] input: rk8xx_pwrkey as /devices/platform/ff160000.i2c/i2c-1/1-0018/input/input1
[    2.241138] rk808-rtc rk808-rtc: device is disabled
[    2.241154] rk808-rtc: probe of rk808-rtc failed with error -22
[    2.241218] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff800956c000
[    2.242963] lirc_dev: IR Remote Control driver registered, major 239
[    2.242979] IR NEC protocol handler initialized
[    2.242994] IR RC5(x/sz) protocol handler initialized
[    2.243009] IR RC6 protocol handler initialized
[    2.243023] IR JVC protocol handler initialized
[    2.243037] IR Sony protocol handler initialized
[    2.243051] IR SANYO protocol handler initialized
[    2.243065] IR Sharp protocol handler initialized
[    2.243079] IR MCE Keyboard/mouse protocol handler initialized
[    2.243093] IR LIRC bridge handler initialized
[    2.243107] IR XMP protocol handler initialized
[    2.243516] of_get_named_gpiod_flags: parsed 'gpios' property of node '/ir-receiver[0]' - status (0)
[    2.243577] Registered IR keymap rc-pine64
[    2.243994] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1/input2
[    2.244257] rc1: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1
[    2.244713] input: MCE IR Keyboard/Mouse (gpio-rc-recv) as /devices/virtual/input/input3
[    2.245184] rc rc1: lirc_dev: driver ir-lirc-codec (gpio-rc-recv) registered at minor = 0
[    2.246207] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio1-supply from device tree
[    2.246334] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio2-supply from device tree
[    2.246921] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio3-supply from device tree
[    2.247032] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio4-supply from device tree
[    2.247589] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio5-supply from device tree
[    2.247665] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio6-supply from device tree
[    2.247736] rockchip-iodomain ff100000.syscon:io-domains: Looking up pmuio-supply from device tree
[    2.249552] rockchip-thermal ff250000.tsadc: Missing tshut mode property, using default (cru)
[    2.249564] rockchip-thermal ff250000.tsadc: Missing tshut-polarity property, using default (low)
[    2.250425] Bluetooth: Virtual HCI driver ver 1.5
[    2.250669] Bluetooth: HCI UART driver ver 2.3
[    2.250676] Bluetooth: HCI UART protocol H4 registered
[    2.250680] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.250791] usbcore: registered new interface driver bfusb
[    2.250900] usbcore: registered new interface driver btusb
[    2.250911] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    2.251374] cpu cpu0: leakage=12
[    2.251413] cpu cpu0: Looking up cpu-supply from device tree
[    2.252015] cpu cpu0: Looking up cpu-supply from device tree
[    2.252228] cpu cpu0: Looking up cpu-supply from device tree
[    2.254247] sdhci: Secure Digital Host Controller Interface driver
[    2.254249] sdhci: Copyright(c) Pierre Ossman
[    2.254253] Synopsys Designware Multimedia Card Interface Driver
[    2.254937] dwmmc_rockchip ff500000.rksdmmc: IDMAC supports 32-bit address mode.
[    2.254958] dwmmc_rockchip ff500000.rksdmmc: Using internal DMA controller.
[    2.254968] dwmmc_rockchip ff500000.rksdmmc: Version ID is 270a
[    2.255007] dwmmc_rockchip ff500000.rksdmmc: DW MMC controller at irq 37,32 bit host data width,256 deep fifo
[    2.255028] dwmmc_rockchip ff500000.rksdmmc: Looking up vmmc-supply from device tree
[    2.255120] dwmmc_rockchip ff500000.rksdmmc: Looking up vqmmc-supply from device tree
[    2.255178] dwmmc_rockchip ff500000.rksdmmc: GPIO lookup for consumer cd
[    2.255182] dwmmc_rockchip ff500000.rksdmmc: using device tree for GPIO lookup
[    2.255198] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/rksdmmc@ff500000[0]' - status (0)
[    2.255224] dwmmc_rockchip ff500000.rksdmmc: Got CD GPIO
[    2.255229] dwmmc_rockchip ff500000.rksdmmc: GPIO lookup for consumer wp
[    2.255233] dwmmc_rockchip ff500000.rksdmmc: using device tree for GPIO lookup
[    2.255238] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/rksdmmc@ff500000[0]'
[    2.255243] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/rksdmmc@ff500000[0]'
[    2.255247] dwmmc_rockchip ff500000.rksdmmc: using lookup tables for GPIO lookup
[    2.255251] dwmmc_rockchip ff500000.rksdmmc: lookup for GPIO wp failed
[    2.268198] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.282717] dwmmc_rockchip ff500000.rksdmmc: 1 slots initialized
[    2.285275] dwmmc_rockchip ff520000.rksdmmc: IDMAC supports 32-bit address mode.
[    2.285306] dwmmc_rockchip ff520000.rksdmmc: Using internal DMA controller.
[    2.285315] dwmmc_rockchip ff520000.rksdmmc: Version ID is 270a
[    2.285359] dwmmc_rockchip ff520000.rksdmmc: DW MMC controller at irq 38,32 bit host data width,256 deep fifo
[    2.285388] dwmmc_rockchip ff520000.rksdmmc: Looking up vmmc-supply from device tree
[    2.285492] dwmmc_rockchip ff520000.rksdmmc: Looking up vqmmc-supply from device tree
[    2.286021] dwmmc_rockchip ff520000.rksdmmc: GPIO lookup for consumer wp
[    2.286026] dwmmc_rockchip ff520000.rksdmmc: using device tree for GPIO lookup
[    2.286032] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/rksdmmc@ff520000[0]'
[    2.286037] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/rksdmmc@ff520000[0]'
[    2.286041] dwmmc_rockchip ff520000.rksdmmc: using lookup tables for GPIO lookup
[    2.286046] dwmmc_rockchip ff520000.rksdmmc: lookup for GPIO wp failed
[    2.288172] usb 1-1: new high-speed USB device number 2 using dwc2
[    2.298200] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.310746] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    2.310795] mmc0: new high speed SDHC card at address 59b4
[    2.311308] mmcblk0: mmc0:59b4 EB2MW 29.8 GiB
[    2.312636] dwmmc_rockchip ff520000.rksdmmc: 1 slots initialized
[    2.312754] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.314015]  mmcblk0: p1 p2
[    2.315260] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/standby-led[0]' - status (-517)
[    2.315366] ledtrig-cpu: registered to indicate activity on CPUs
[    2.315421] hidraw: raw HID events driver (C) Jiri Kosina
[    2.315743] usbcore: registered new interface driver usbhid
[    2.315745] usbhid: USB HID core driver
[    2.318481] rk3328-codec ff410000.codec: spk_depop_time use default value.
[    2.321804] NET: Registered protocol family 10
[    2.322576] NET: Registered protocol family 17
[    2.322682] Bluetooth: RFCOMM socket layer initialized
[    2.322711] Bluetooth: RFCOMM ver 1.11
[    2.322725] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.322732] Bluetooth: HIDP socket layer initialized
[    2.322931] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    2.323056] [BT_RFKILL]: Enter rfkill_rk_init
[    2.323162] Key type dns_resolver registered
[    2.324475] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/standby-led[0]' - status (-517)
[    2.324762] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]'
[    2.324766] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]'
[    2.325228] asoc-simple-card hdmi-sound: i2s-hifi <-> ff000000.i2s mapping ok
[    2.326274] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]'
[    2.326279] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]'
[    2.328219] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    2.346804] asoc-simple-card sound: rk3328-hifi <-> ff010000.i2s mapping ok
[    2.347246] asoc-simple-card sound: snd-soc-dummy-dai <-> ff010000.i2s mapping ok
[    2.348440] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]'
[    2.348445] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]'
[    2.348861] asoc-simple-card spdif-sound: dit-hifi <-> ff030000.spdif mapping ok
[    2.349593] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/standby-led[0]' - status (-517)
[    2.349896] hctosys: unable to open rtc device (rtc0)
[    2.358273] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[    2.368699] rockchip-pm-domain ff100000.syscon:power-controller: failed to get ack on domain 'pd_video', val=0x10040
[    2.378723] rockchip-pm-domain ff100000.syscon:power-controller: failed to get ack on domain 'pd_vpu', val=0x10040
[    2.380485] ALSA device list:
[    2.380488]   #0: HDMI
[    2.380489]   #1: I2S
[    2.380491]   #2: SPDIF
[    2.398207] mmc_host mmc1: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[    2.428918] vendor storage:20160801 ret = 0
[    2.574823] usb 3-1: new full-speed USB device number 2 using ohci-platform
[    2.752225] usb 1-1: New USB device found, idVendor=0bda, idProduct=8179
[    2.752230] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.752234] usb 1-1: Product: 802.11n WLAN NIC
[    2.752238] usb 1-1: Manufacturer: Realtek
[    2.753386] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/standby-led[0]' - status (-517)
[    2.768560] usb 3-1: New USB device found, idVendor=046d, idProduct=c52b
[    2.768565] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.768570] usb 3-1: Product: USB Receiver
[    2.768574] usb 3-1: Manufacturer: Logitech
[    2.777468] input: Logitech USB Receiver as /devices/platform/ff5d0000.usb/usb3/3-1/3-1:1.0/0003:046D:C52B.0001/input/input4
[    2.804653] Freeing unused kernel memory: 2880K
[    2.828849] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-ff5d0000.usb-1/input0
[    2.835151] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/standby-led[0]' - status (-517)
[    2.840298] input: Logitech USB Receiver as /devices/platform/ff5d0000.usb/usb3/3-1/3-1:1.1/0003:046D:C52B.0002/input/input5
[    2.891960] hid-generic 0003:046D:C52B.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-ff5d0000.usb-1/input1
[    2.892292] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/standby-led[0]' - status (-517)
[    2.899871] hid-generic 0003:046D:C52B.0003: hiddev0,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-ff5d0000.usb-1/input2
[    2.900175] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/standby-led[0]' - status (-517)
[    4.453861] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    4.455008] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    4.646766] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    9.189279] random: nonblocking pool is initialized
[   18.635639] systemd[1]: System time before build time, advancing clock.
[   18.644764] systemd[1]: systemd 232 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK -SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL -XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[   18.645248] systemd[1]: Detected architecture arm64.
[   18.646758] systemd[1]: Set hostname to <Lakka>.
[   18.705903] systemd[1]: Listening on Journal Socket.
[   18.706520] systemd[1]: Listening on udev Kernel Socket.
[   18.707971] systemd[1]: Created slice System Slice.
[   18.710340] systemd[1]: Mounting Debug File System...
[   18.712798] systemd[1]: Starting Samba Configuration...
[   18.714033] systemd[1]: Created slice User and Session Slice.
[   18.715423] systemd[1]: Listening on udev Control Socket.
[   18.718881] systemd[1]: Starting Debug Shell on /dev/ttyFIQ0...
[   18.722111] systemd[1]: Mounting POSIX Message Queue File System...
[   18.722981] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   18.723760] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   18.724474] systemd[1]: Listening on Journal Socket (/dev/log).
[   18.747005] systemd[1]: Starting Load Kernel Modules...
[   18.749723] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   18.752621] systemd[1]: Starting Setup machine-id...
[   18.753062] systemd[1]: Reached target Slices.
[   18.753491] systemd[1]: Reached target Swap.
[   18.756536] systemd[1]: Mounting Temporary Directory...
[   18.764083] systemd[1]: Starting Remount Root and Kernel File Systems...
[   18.765114] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   18.767551] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '-v2.1-rc3-1261-g870ffe9', rk_ko_ver is '5', built at '10:24:13', on 'Sep 29 2017'.
[   18.767782] mali-utgard ff300000.gpu: mali_platform_device->num_resources = 9
[   18.767797] mali-utgard ff300000.gpu: resource[0].start = 0x0x00000000ff300000
[   18.767804] mali-utgard ff300000.gpu: resource[1].start = 0x0x00000000ff300000
[   18.767811] mali-utgard ff300000.gpu: resource[2].start = 0x0x0000000000000011
[   18.767819] mali-utgard ff300000.gpu: resource[3].start = 0x0x0000000000000012
[   18.767826] mali-utgard ff300000.gpu: resource[4].start = 0x0x0000000000000013
[   18.767833] mali-utgard ff300000.gpu: resource[5].start = 0x0x0000000000000014
[   18.767840] mali-utgard ff300000.gpu: resource[6].start = 0x0x0000000000000015
[   18.767847] mali-utgard ff300000.gpu: resource[7].start = 0x0x0000000000000016
[   18.767854] mali-utgard ff300000.gpu: resource[8].start = 0x0x0000000000000017
[   18.767862] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 518; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali.
[   18.767893] mali-utgard ff300000.gpu: Looking up mali-supply from device tree
[   18.768745] devfreq ff300000.gpu: Couldn't update frequency transition information.
[   18.769374] systemd[1]: Mounting Variable Directory...
[   18.769857] systemd[1]: Reached target Paths.
[   18.770862] systemd[1]: Listening on RPCbind Server Activation Socket.
[   18.771581] systemd[1]: Reached target RPC Port Mapper.
[   18.772106] Mali: Mali device driver loaded
[   18.772919] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/standby-led[0]' - status (-517)
[   18.781911] systemd[1]: Mounted Debug File System.
[   18.782500] systemd[1]: Mounted POSIX Message Queue File System.
[   18.783049] systemd[1]: Mounted Variable Directory.
[   18.783571] systemd[1]: Mounted Temporary Directory.
[   18.786197] systemd[1]: Started Samba Configuration.
[   18.788981] systemd[1]: Started Debug Shell on /dev/ttyFIQ0.
[   18.791268] systemd[1]: Started Load Kernel Modules.
[   18.793022] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   18.794731] systemd[1]: Started Setup machine-id.
[   18.796834] systemd[1]: Started Remount Root and Kernel File Systems.
[   18.833100] systemd[1]: Starting udev Coldplug all Devices...
[   18.835884] systemd[1]: Starting Journal Service...
[   18.839698] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.842724] systemd[1]: Mounting Configuration File System...
[   18.846301] systemd[1]: Starting Apply Kernel Variables...
[   18.849364] systemd[1]: Starting Setup Timezone data...
[   18.860910] systemd[1]: Mounted Configuration File System.
[   18.869431] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.877415] systemd[1]: Reached target Local File Systems (Pre).
[   18.880993] systemd[1]: Reached target Local File Systems.
[   18.885783] systemd[1]: Started Setup Timezone data.
[   18.895175] systemd[1]: Started Apply Kernel Variables.
[   19.001995] systemd[1]: Started Journal Service.
[   19.025756] systemd-journald[259]: Received request to flush runtime journal from PID 1
[   20.229670] rk_gmac-dwmac ff540000.ethernet: rk_get_eth_addr: mac address: 3e:49:bb:ba:56:31
[   20.229687] eth0: device MAC address 3e:49:bb:ba:56:31
[   20.232273] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/standby-led[0]' - status (-517)
[  289.589252] drm_crtc_check_viewport: skip check
[  307.298762] drm_crtc_check_viewport: skip check
[ 1125.902163] rk_gmac-dwmac ff540000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
The above dmesg log is from my first bootup of the Lakka test image :
Linux Lakka 4.4.83 #1 SMP Fri Sep 29 10:33:18 CDT 2017 aarch64 GUN/Linux
git version  28397b3
Rock64.arm-8.1.2
marcushh_Pb
retroarch does start;  there are a couple of fonts missing, but most gnu+linux stuff works from busybox;  python2.7 runs fine, nano and vim work (filesystem is ok), I am able to play around in the retroarch menu, see system information, exit and reboot;  no problems.
There are no roms apparently;  have not tried to play any games , nor have I tested my game pads yet.  I left you some more detailed messages on  irc  ( use !msg get ) .
I'll be around my lab on Saturday should you have questions, catch me on IRC.
marcushh_Pb
Shy
notes:
   Icons do not appear on the retroarch console menu;  I tried to load content;  and it did download;  but I must be doing something wrong, because can't seem to do anything with it;  I can navigate the console menu however;
The wifi settings fail to see my wifi dongle ;  scan doesn't see local networks;
marcushh_Pb
Shy
My internet is broken, so can't complete the image download - once I have it sorted out I'll test the image.
Marcus, as for ROMs - no distribution can include ROMs, thats why they are not there Smile
I'm interested in trying it also, but can not find anywhere to download it. I understand it is BETA, but I'd like to help test it and report bugs.
(10-03-2017, 10:24 AM)dudemo Wrote: I'm interested in trying it also, but can not find anywhere to download it. I understand it is BETA, but I'd like to help test it and report bugs.
It hasn't been made public, but given that as much feedback as possible is a good thing at an early stage I think its ok to share it on here. Do keep in mind its pre-release.
You can download the image here to test out and provide feedback.
Awesome, Luke. Thanks! I'll definitely keep in mind that this is prerelease and treat it as such.
Finally got around to trying it out ... sadly, it doesn't load retroarch assets. Also, it doesn't auto-start - i need to launch retroarch manually.
RetroArch will probably autostart if you remove textmode (or replace it with quiet) in extlinux/extlinux.conf on the boot partition
(10-10-2017, 02:43 PM)Kwiboo Wrote: RetroArch will probably autostart if you remove textmode (or replace it with quiet) in extlinux/extlinux.conf on the boot partition
Yes. Still its weird that the assets don't load ... I experienced this in the past putting together a dedicated Retroarch build for the Pine64 - I remember that it was a permissions issue. Didn't have time to look into this - but I think the nature of the issue is different as the Lakka build runs as root.
(10-10-2017, 07:02 AM)Luke Wrote: Finally got around to trying it out ... sadly, it doesn't load retroarch assets. Also, it doesn't auto-start - i need to launch retroarch manually.
hi lukasz;  same two issues.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,372 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 617 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 612 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,415 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,691 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  Disabling last mount time check on boot acwest 0 627 03-03-2023, 09:24 PM
Last Post: acwest
