Does the ROCK64 use any closed source boot loaders, firmware, drivers or other blobs?
Does the ROCK64 use any closed source boot loaders, firmware, drivers or other non-open blobs?
If so, how many and for which components?  Thanks!
What I saw so far is a first stage loader that is a binary (check https://github.com/ayufan-rock64/rkbin/tree/master/rk33 or RK's upstream) and of course ARM Mali. As boot0 in the case of Allwinner this loader initializes DRAM and then hands off to u-boot. RK has released u-boot spl as a replacement for this loader for RK3399 and RK3288, RK3368, so we should get a u-boot spl for RK3328 at some point. Otherwise you can check out their BSP sources at https://github.com/rockchip-linux
Okay, so to summarize @xalius's above post, we have:
Boot requires:
first stage boot loader (closed blob) -> u-boot (closed blob) -> Linux kernel (open)
However, this might improve to:
first stage boot loader (closed blob) ->  u-boot spl for RK3328 (open?) -> Linux kernel (open)
(Aside: According to info at https://github.com/rockchip-linux/u-boot, it looks like "spl" stands for secondary program loader.)
Also, the using ARM Mali GPU requires a closed blob driver.  For all HDMI output?  Or just for 2D and/or 3D hardware acceleration?
Is the network driver open?
Thanks!
first stage loader is closed, uboot is open
spl will in the future replace first stage loader
Mali is needed only for 3D acceleration, there's no 2D acceleration.
HDMI is driven by open source drivers. Kernel configures DW HDMI registers and maps memory where the FB is stored to be render by HDMI controller. The same FB is used by Mali to render 3D content. AFAIK all the rest codes to handle VPU are open.
So, closed blobs are:
- first stage loader with DRAM init code,
- MALI driver,
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
are wifi and ethernet open or just drivers from the chip maker? it is hard for me to figure out what is going on in
https://github.com/ayufan-rock64/rkbin/t...mware/wifi
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 159 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,377 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 345 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 631 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 621 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,494 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 191,110 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 605 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 658 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  Disabling last mount time check on boot acwest 0 636 03-03-2023, 09:24 PM
Last Post: acwest
