Keyboard not popping up on QT apps
My Pinephone broke and I switched to Droidian, but I don't think this is a Droidian-specific question. Forgive me if it turns out to be irrelevant.
Anyway, my on-screen keyboard works fine on most apps, but I installed both Nextcloud client and Chromium browser, and in both cases, focusing on a text field doesn't cause the keyboard to deploy. The common denominator here is that both of these apps use QT and not GTK, and I assume this is relevant.
Has any one had this issue, and if so, how did you resolve it?
No, Chromium does not use Qt. The Nextcloud client does.
I assume you use Phosh? You should be able to force the keyboard to pop up manually, see https://forum.pine64.org/showthread.php?tid=19045.
  icon keyboard chris_02 3 426 02-09-2024, 08:53 AM
Last Post: 3x5co
  Keyboard keeps disappearing the moment it's touched jojuma 1 516 10-29-2023, 08:34 AM
Last Post: walter1950
  New keyboard issue sandspur 29 12,459 10-05-2023, 02:27 AM
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 1,105 07-07-2023, 03:29 AM
Last Post: jojuma
  Battery problem with a Pinephone keyboard and Mobian elode 2 2,210 12-22-2022, 07:10 PM
Last Post: acid andy
  Would creating a 2 row landscape keyboard be difficult? rp3 1 1,122 09-09-2022, 06:49 AM
Last Post: zetabeta
  Making a new keyboard layout Eugo 2 1,498 08-28-2022, 04:15 AM
Last Post: Eugo
  PP Keyboard doesn't charge Pinephone (Mobian) jojuma 1 1,241 08-06-2022, 01:10 AM
Last Post: elode
  PP keyboard not working at all jojuma 3 1,804 08-03-2022, 10:02 AM
Last Post: jojuma
  on screen keyboard woes vusra 1 1,251 07-18-2022, 03:29 AM
Last Post: vusra
