icon keyboard
Under bookworm, the keyboard icon appears at the bottom right of the screen when you activate an application with which you can use it, but under trixie the keyboard icon doesn't appear.
What configuration needs to be activated for the keyboard icon to appear at the bottom right of the screen?
Thanks,
@+ Chris
There is no configuration. This is Phosh, it follows the GNOME design philosophy, which basically says no options, ever.
As I understand it, you are supposed to hold the finger on the bottom bar for a while until the keyboard pops up. Do not ask me who thought such an undiscoverable feature was good design.
(What they did in Phosh 0.36.0 is that they added an option… allowing you to configure for how long you have to hold the finger until the keyboard pops up! No kidding.)
(02-07-2024, 09:35 PM)Kevin Kofler Wrote: There is no configuration. This is Phosh, it follows the GNOME design philosophy, which basically says no options, ever.
it works!
Tanks Kevin
It worked for me too! That's great, but yeah, how on earth is anyone supposed to know this intuitively?
  Keyboard not popping up on QT apps 3x5co 1 252 02-08-2024, 11:45 PM
  Keyboard keeps disappearing the moment it's touched jojuma 1 521 10-29-2023, 08:34 AM
Last Post: walter1950
  New keyboard issue sandspur 29 12,526 10-05-2023, 02:27 AM
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 1,109 07-07-2023, 03:29 AM
Last Post: jojuma
  Battery problem with a Pinephone keyboard and Mobian elode 2 2,213 12-22-2022, 07:10 PM
Last Post: acid andy
  The settings icon disappeared kubussz 34 13,814 11-15-2022, 10:56 AM
  Would creating a 2 row landscape keyboard be difficult? rp3 1 1,124 09-09-2022, 06:49 AM
Last Post: zetabeta
  Making a new keyboard layout Eugo 2 1,501 08-28-2022, 04:15 AM
Last Post: Eugo
  PP Keyboard doesn't charge Pinephone (Mobian) jojuma 1 1,245 08-06-2022, 01:10 AM
Last Post: elode
  PP keyboard not working at all jojuma 3 1,805 08-03-2022, 10:02 AM
Last Post: jojuma
