PP keyboard not working at all
Today my PP keyboard arrived, but doesn't work.
Since it's charging my PP, i suppose, the connection of the pins is fine.
Now I read in the instructions post, I need the KB151 driver. But before I reinstall the whole system, this results in the following questions:
1. How can I check, if this driver is present?
2. If it isn't, can I install it or do I have to reinstall the whole OS?
3. If I do have to reinstall the whole OS, how do I know if the kernel does include this driver (I read, that in stable, the driver is not present)?
Thanks for helping me
Try updating to the latest version of mobian. There were kernels without drivers for a while in May.
See https://forum.pine64.org/showthread.php?tid=16756
Although at the moment it is possible that a later update has affected charging and reporting of battery levels.
https://forum.pine64.org/showthread.php?...#pid111668
Thanks for your answer.
I am on the latest stable version. The other threads don't have a final solution as it seems.
In one thread is said, that it works now with the latest version, but with the latest version of what? That isn't mentioned (I asked there, too).
sudo modprobe kb151 tells me, that kb151 isn't there. The question remains: can I install that driver or must it be part of the kernel? Do I have to flash a version of the OS whose kernel contains it?
Thanks again
I don't know what I did, but it seems to work now. I didn't do anything special. But after another reboot it suddenly worked. Thanks. I'll mark this as solved.
  icon keyboard chris_02 3 423 02-09-2024, 08:53 AM
Last Post: 3x5co
  Keyboard not popping up on QT apps 3x5co 1 245 02-08-2024, 11:45 PM
  Mobile internet via cellular network mostly not working Anna 18 10,276 01-19-2024, 02:59 AM
Last Post: anonymous
Exclamation The internal speaker stops working anonymous 6 1,020 01-17-2024, 05:53 PM
  Keyboard keeps disappearing the moment it's touched jojuma 1 510 10-29-2023, 08:34 AM
Last Post: walter1950
  New keyboard issue sandspur 29 12,450 10-05-2023, 02:27 AM
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 1,101 07-07-2023, 03:29 AM
Last Post: jojuma
  APN settings not working with new operator SIM card user641 1 1,036 03-01-2023, 04:43 PM
  Possible Solution for Microphone Not Working Ferriah 0 949 02-13-2023, 01:09 PM
Last Post: Ferriah
  Battery problem with a Pinephone keyboard and Mobian elode 2 2,204 12-22-2022, 07:10 PM
Last Post: acid andy
