DietPi OS for Pinebook Pro
[Image: dietpi-logo_192x192.png]
DietPi is an extremely lightweight Debian-based OS. It is highly optimised for minimal CPU and RAM resource usage, ensuring your Pinebook always runs at its maximum potential.
Use dietpi-software to quick and easy install a desktop and lots of other Ready to Run & Optimised applications for your system. DietPi will do all the necessary configurations, including starting the services.
DietPi images are available for PINE A64PINE H64PinebookPinebook Pro, ROCK64 and ROCKPro64 and all Quartz64 models.
Our PINE64 images are based on the great kernel and firmware, developed by Armbian. However, if you face any issues, please contact us via forum or GitHub issue first.
Website: https://dietpi.com/
Download images: https://dietpi.com/#download
Documentation: https://dietpi.com/docs/
Blog: https://dietpi.com/blog/
Forums: https://dietpi.com/phpbb/
GitHub repository: https://github.com/MichaIng/DietPi
DietPi is a free and open-source project. We are be happy if you consider to contribute or donate: https://dietpi.com/contribute.html
Consider to share your donation between DietPi and Armbian.
Image has been updated to ship latest DietPi v7.7 based on Debian Bullseye: https://dietpi.com/downloads/images/Diet...ullseye.7z
nvme doesn't work and the graphics are really slow (X11)
Also seems like some of the patches are not included for the kernel ( 5.15.2-rockchip64 #trunk.61 SMP PREEMPT Wed Nov 17 08:49:40 UTC 2021 aarch64 GNU/Linux)
[ 298.867535] Purging 131072 bytes
[ 2101.398573] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x000000008FFF9300
Reason: TODO
raw fault status: 0x2F002C1
decoded fault status: SLAVE FAULT
exception type 0xC1: TRANSLATION_FAULT_1
access type 0x2: READ
source id 0x2F0
[ 2101.398677] panfrost ff9a0000.gpu: js fault, js=0, status=JOB_BUS_FAULT, head=0x4fcf880, tail=0x4fcf880
[ 2101.909101] panfrost ff9a0000.gpu: gpu sched timeout, js=0, config=0x3b00, status=0x8, head=0x30a2680, tail=0x30a2680, sched_job=00000000dceb3bc4
[ 2101.909564] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x000000008FFF9240
Reason: TODO
raw fault status: 0x4F002C1
source id 0x4F0
[ 2101.909648] panfrost ff9a0000.gpu: js fault, js=0, status=JOB_BUS_FAULT, head=0x30e3840, tail=0x30e3840
Thanks for your report.
The image should ship with Linux 5.10 (stable) and not 5.15 (testing), so you should test it with the shipped Linux 5.10 when reporting issues.
X11 is driven via KMS (modesetting DDX driver) and Mesa 20.3.5 from regular Debian Bullseye repository, which should give decent performance, though it depends on the actual application. I don't have a Pinebook Pro, but another RK3399 SBC where desktops in general, browsers and Kodi work quite well. How did you benchmark and what did you compare with?
  Debian on Pinebook Pro u974615 7 1,010 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,590 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,143 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,220 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,803 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,232 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,268 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,480 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,585 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 660 07-13-2023, 05:21 PM
Last Post: owaspfap
