Mobile Roaming Not Working
I am currently using the Pinephone CE 3BG edition with the current Arch|Phosh build.  It is using Freedom (Shaw mobile) in Canada, and calls, SMS and data all work, despite having to reset and reboot regularly. However, once I move off the fairly limited Shaw cellular network the phone never roams over to another network, of which there are two big ones in Canada, Telus and Bell.
I know many people have to manually connect to their network so I don't know if I am being a little hopeful but....
Questions:
Is anyone using the pinephone on Telus or Bell and did you have to do anything to access the network?
Is roaming part of the modem's responsibilities? Or is this a current software limitation where roaming
information from the network provider is not being used or stored yet?
Is there a manual way to provide roaming information or configuration to the modem?
TIA
LF
Don't know the answer but a related question may be how to view/select available cell networks on a pinephone. Some kind equivalent linux software to SIM Tools or the builtin function on feature phones may be required.
This 'may' have to do with your APN settings.
Here in the USA I am using a MVNO of T-Mobile (Simple Mobile)
I found I need a different APN when the signal changes from 4g to 3g.
They both 'work' but require different APN's.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  4G VoLTE calls confirmed working with carrier x dcinoz 15 11,953 03-09-2024, 11:38 PM
Last Post: dcinoz
  can I retrieve accidentally deleted voice mail with T mobile ? HLing 4 867 12-13-2023, 01:24 AM
Last Post: oldschool
  New Zealand network providers mobile data Linux2thabone 3 3,304 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 10 3,312 07-07-2023, 12:06 PM
Last Post: jovval
  Problems updating KDE Plasma Mobile OS IMSAI8080 6 3,390 06-30-2023, 11:39 PM
Last Post: ionmich
  Current Situation With Setup and Carrier Activation With Tracfone Verizon T-Mobile pinephoneuser22 0 713 05-26-2023, 08:40 PM
Last Post: pinephoneuser22
  Cannot call at several mobile phones Gon 3 1,349 05-04-2023, 05:18 AM
Last Post: Gon
  MMS sending stopped working amindfv 2 1,250 01-16-2023, 09:44 PM
Last Post: treebeard
  Instructions to get pinephone working on USA carrier omarcomputing 1 1,378 10-08-2022, 04:45 PM
Lightbulb pinephone mobile dock jasmin763 2 1,732 06-06-2022, 09:06 AM
Last Post: 98cwitr
